Results 1 to 2 of 2
Thread: filtering weirdness- please confirm
    I have been getting aquainted with the new spreadsheet editor and am having a hard time getting filtering to behave the way at should (or the way I think it should). Sometimes the filtering works, but other times it doesn't.
    Here's one time it didn't-- as you can see in the image, I have turned filtering on for the channels and I filtered out some things... BUT they still show up in the menu.
    Also, sometimes when it does filter, and then I click to turn it off, it doesn't always turn off the filtering.
    Maybe there's a trick to it? Is anyone else having problems with this?
    Thanks,
    ~Mechis
    Someone on another forum said this was a bug and that channel filtering works properly if you turn on item filtering also.
    ~Mechis
