Thread: How can you make a "cookie cutter" type cut in a poly?
    Question How can you make a "cookie cutter" type cut in a poly?
    Well the title says it all, I just want to know how to cut a hole in a poly without having to use the knife tool. For example if you wanting a round cut in a poly, is there any way to do that? Thanks a lot for helping out, as I am sure this is a newbie question (well I am a newbie, so I ge to ask newbie questions )
    Lightwave Pimp Skonk's Avatar
    Yorkshire UK
    1,450
    Create the cutter object and put it as a background layer and put the object u want to cut in the forground then use the "Drill" or "Solid Drill" tool set to "Stencil".
    James..
    uh wha?
    Thanks so much (I knew it was a newbie question)
    Banned Epita's Avatar
    Not where you are
    379
    you could use the make gear function, somewhere and go from that...
    Epita
