Thread: uv edit pro Uv vs LW Uv
    Chesapeake, Va.
    49
    What is the difference between a uv map created in lw and one created in uv edit pro? When I take a uv I created in lw, make adjustments in uv edit pro and save it, no longer am I able to make use of lw to drag uv points around. When I drag a point, it is as if all the points have been unwelded.
    Is there a way to convert it back to a uv that can be edited within lw texture window?
    thanks,
    Rich
    Huge Member mkiii's Avatar
    West Sussex UK
    1,102
    Just unweld the points once you get back into LW & carry on Uv'ing as normal.
    Chesapeake, Va.
    49
    Thanks for the help
