Thread: Reducing object size and textures
    I just did a tutorial on how to make a desert, but the ground is just too big (about 14.5 km too big). When I scaled the ground down in modeler the displacement maps and textures stayed the same size. Is there a way to scale down the textures and the object at the same time? Thanks for your help!
    -Seacrest out!
    Trying is the first step twards failure.
    Stuper Member
    PA USA
    1,043
    You could try parenting the terrain object to a null and using the null as a reference object for the textures. Scaling the null should scale both the terrain and the textures.
    Registered User digimassa's Avatar
    Jan 2004
    balcan-northwest
    331
    or use UV maps
