Thread: Baking moving hypervoxels???
    Question Baking moving hypervoxels???
    Is there a way to bake moving hypervoxels for network rendering???
    ThanX
    Mad Doctor pixelinfected's Avatar
    Jan 2004
    Santa Margherita Ligure
    614
    from my knowledge is impossibile to bake an animated hypervoxel
    sorry, idem spread on a lan the baking operation, be cause it build an animation, and it's no possible from screamernet, only frame sequence...
    sorry
    what do you want to do?
    may be i can help you.
    hhheeeerrrmmmm... I didn't think so. Thanks.
    I have some shots (21 at 2048x1556) where Firefighting planes are dumping water on forest fires.
    The only way I've come up with where the water looks good at all is using hypervoxel sprites.
    Any ideas would be appreciated.
    ThanX again.
    Registered User Noclar7's Avatar
    New Brunswick, Canada
    331
    do you mean baking your keys? because you have to do this in order to render properly over a network.
    open up your FX_Browser and in the "File" tab click "save motion".
    then save the .pfx file to your shared content directory.
    Other than that, you can "bake" hypervoxels if they are in volume mode. Click on the shading->basic when in volume mode to select your baking options.
    happy cooking .
    RJ Forbes
    Coral House
    Application Development, 3d Animation, Video Production
    Jan 2004
    614
    1) did two, three render of splash from different view, and use it projected on plane, instead of use all hypervoxel render
    2) think to buy realflow, and produce geometry instead od hypervoxel, more fast solution
