Results 1 to 15 of 18
Thread: Lost out to switcher on 4909
    VT5 USER Rich Deustachio's Avatar
    Mount Laurel, NJ
    1,371
    Patch 4909 has lost the out to switcher feature so we can no longer see our text on the program output from the CG for text placement.
    Just Tryin' To Help...
    Quincy, Illinois, USA
    1,066
    that will be a royal pain.....
    SB Enterprises, Quincy, Illinois ~ in the backwoods of the US of A
    Pleasant Grove, UT
    87
    Rich--
    I've got 4909 installed, and the "out to switcher" check box is working OK here. No problems.
    Not sure what's going on there.
    Tim Johnson
    Graff!c Jam
    Pleasant Grove, UT
    Unhappy
    Uh oh. Same here.
    When checking the "VT-Vision" box under View/Output, I get the switcher ouput, but no CG overlay...
    Mount Laurel, NJ
    1,371
    We are talking about two different boxes. The one that Taiji is talking about shows the VT-Vision in the CG and as he states you can't see the text and the other box which is the out to switcher box, I am getting no output to switcher from the CG.
    Rich,
    You're right, but I am also assuming that they are related.
    My "Out to Switcher" function is not working either.
    Is your VT-Vision in the CG working or not working?
    Mount Laurel, NJ
    1,371
    No it isn't, same as yours.
    BTW, does anyone know whether it is better to post these sorts of things here or directly to the "bug catchers?"
    Hmm. I just checked the Microsoft site.
    DirectX 9.0b is still the latest version of DirectX, which is what I have installed. So that's not it...
    I wonder why Tim is so special, that his is working?
    Are we there yet? RomainR's Avatar
    Paris, France
    408
    It's working for me.
    You should post your systems config, maybe it's related.
    Have a Great Day
    Unhappy
    Aww shucks, I just tried an uninstall of Patch03 and a reinstall.
    VT-Vision and Out to Switcher still don't work...
    An nvidia driver compatability issue?
    I hope not, because the latest nvidia drivers don't work for this one particular workstation's dual monitor set up.
    W2K Pro SP4
    Supermicro X5DA8
    Dual Xeon 3 GHz
    2 GB RAM
    NVIDIA Quadro4 980 XGL (driver 4.1.0.3)
    DirectX 9.0b
    Mount Laurel, NJ
    1,371
    I really need to know what the story is on this CG problem. I am in the middle of several CG intesive projects that I need to see what they are being overlayed on for positining purposes. Is this problem going to be resolved soon or should I just go back to the previous patch?
    I think there was a problem with the first release of Patch 3.
    Try downloading it again. Uninstall VT. and reinstall it with the new patch.
    XDCAM HD production ScorpioProd's Avatar
    Albany, NY
    4,346
    Guys, don't panic.
    I just tried it and saw the same problem.
    So, I thought to myself, what would logically be connected with the CG out to switcher OR TVision under the CG?
    Logically, the DSK.
    So, I simply opened the switcher and turned the DSK on and off and VOILA, everything works as expected now.
    Eugene
    Scorpio Productions
