Results 1 to 2 of 2
Thread: Bright edges on shadowmaped shadow....
    Malmö, SWEDEN
    7,639
    Hello!
    Here is my problem: I´ve got an object which has front projection turned on (alpha is set to shadow density). When the butterfly cast a shadow on this object, there is a bright edge on the shadow. Any ideas what causing this? I had another problem like this, but it was solved when turning smoothing off (on the object which recieves the shadow). But in this case it doesn´t seem to make any difference.
    Please take a look at this example: QT Video, aproxx 650 Kb Pay attention to the shadow on the flower...
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    Intel Core i7-4790K @ 4GHz
    16GB Ram
    GeForce GTX 1080 8GB
    Windows 10 Pro x64
    Malmö, SWEDEN
    7,639
    Hello!
    I just discovered that Diffuse was little too high. By lowering the amount to about 50% the bright edges dissapeard.
    16GB Ram
    Windows 10 Pro x64
