Thread: Blurring the reflection channel
    marcopolio
    Guest
    Lightbulb Blurring the reflection channel
    I have a material that is reflective, and I want to be able to blur the environment that is reflected in the surface. I havent been able to find any good ways to do this online. Can anyone point me in the right direction, or suggest a method to do this?
    -A
    houston
    96
    render the reflections as a seperate pass and blur them in photoshop or after effects, or any other paint or compositing program I guess.
    2X2GB G5
    2.5GB RAM
    ATI Radeon 9600XT
    north carolina USA
    245
    how about ,surface editor/environment/blur reflections?
    marcopolio
    Guest
    Ah, thanks! Nothing like a good simple solution!
    marcopolio
    Guest
    houston
    96
    That will work too, but if you do it as two seperate layers and comp them together you can adjust the blur amount w/o having to re-render.
    2X2GB G5
    2.5GB RAM
    ATI Radeon 9600XT
    Portland, Maine USA
    19
    also, the higher the number in the blur amount, the longer the render. Especially if it is something of any size. I had that problem with a shiney hardwood floor. With the reflection blurring at 20%, it took forever to render. I jacked the number down to 5%, and it cut the time by about half.
    something to play with to get the balance between the look you want and the time you can take to render.
