Results 1 to 1 of 1
Thread: Inactive vs. Dissolved
    3D Mac Maniac Scazzino's Avatar
    Boston area
    2,554
    On page 12.3 the LW manual states in reference to the scene editor:
    The checkmark column activates or deactivates items. Deactivating an object is like setting its Object Dissolve (Object Properties) to 100%...
    This is not true. Either the manual is incorrect or there is a bug in LW 7.5/7.5b Mac. Setting the object to inactive, still casts shadows and reflections... setting the object dissolve to 100% stops casting of shadows and reflections... (Ideally I would like the checkmark to work just like object dissolve 100%, ie making the object not cast shadows or reflections).
    Steps to reproduce:
    Open new project
    Add->Objects->Load Object... objects/misc/woodplatform.lwo
    Add->Objects->Load Object... objects/misc/chromeball.lwo
    Move platform to... 0,0,1m
    rotate to 0,90,0
    Open surface editor and select the woodplatform:base
    remove the reflection map and set Reflection to 100%
    in Render options: activate raytracing for shadows and reflections
    Render... looks normal...
    Open scene editor and turn the chrome ball inactive by turning off the checkmark...
    Render again, the shadow is still there and even a reflection...
    Instead set the ball object's dissolve to 100% and render again, the shadow and reflection will not be there...
    So which is wrong? The manual or the program?
    -MikeS
    MikeS [LWProfile] 30+ Yrs of Award-winning Media DreamLight.com
    Drag-and-drop-dead-easy™ ScreamerNet - DLI Constellation
    BOOK - Creating a 3D Animated CGI Short & 3D CGI Short Films & DLI Blog
