Results 1 to 2 of 2
Thread: Created DVE icons
    Created DVE icons
    I have become proficient in creating DVE in Aura with the VT Wipe Builder, however, it is a real pain in the switcher interface of VT that neither the icon, the name, or the rollover effect works. How do you create an icon for an .exe, where is this database that is mentioned on screen "dve not in database", and why doesn't the rollover work?
    Running at 29.97 fps Titus's Avatar
    Mexico City
    2,839
    Create a subdirectory in the same directory you have your DVEs, change the name to NewTek Info and put there the preview movies and icons. If you have a DVE with the name trans.dve, then the preview must be trans.dve.avi and the icon trans.dve.jpg.
    There's a way to put your DVEs in a database, so you just write the DVE number (4 digits) and the transition is called. I don't know how to do this.,
    Hope that helps and I understood correctly your question.
