Results 1 to 2 of 2
Thread: Sasquatch error, please help!!!
    When i try using Sasquatch i get some errors. One says:
    "Cact read objects geomtry. Maybe its unsupported LW 6 type. If its normal polygon object, then use LW's Save Object"
    ... i also get the error:
    "failure when reading file, only one layer with points, polygones, or patch is currently supported. skipping later layers."
    Ive tried just about everything to get this to work,.... can someone please let me know what im doing wrong.. thank you so much
    Sounds like an older version of sas. Try freezing your object and put it all in one layer.
    64 bit Win 7 Enterprise
    Dual Intel(R) Xeon Quad Core 2.93GHz
    RAM 24.0 GB
    NVIDIA Quadro FX 5800
    Driver Version 259.81
