Thread: can i create file with lscript
    hello,
    i know it 's possible to write inside a existing text file but i want to know if there is a way to create and write a text file with lscript.
    it's to save and stock some value without to have the right scene open.
    thanx for help
    Yes, it's just as easy as opening a file that already exists.
    Just create a File OA with a new path/filename, and write to it. Don't forget to close it before loading....
    But for storing values, it would be better to use the premade Store() and Recall() functions.
    Blochi
    Sorry but what is a File OA ?
    I haven't read this term before
    I have seen Store and Recall commands but it not the best way for i want to do.
    thank for your help
    File Object Agent .... sorry for beeing so short...
    See the LScript Reference Manual page 5, and Chapter 13.
    -Blochi
    arrghh !!!
    shame on me !!!!
    thanx for all Blochi
    another question if you want :
    i would like to know how to get the " objectcount" of a scene.
    i read the doc and a find nothing about it ( ther's pointcount, polycount but nothing for object.
    the goal is to check if a specific object is present in a scene.
    there a code in doc :
    // Use the firstSelect() and nextSelect()
    // methods to cycle through the objects.
    obj = scene.firstSelect();
    while(obj)
    info(obj);
    obj = scene.nextSelect();
    but it doesn't work in my lightwave although i would make a loop with the "CommandInput" command.
    thanx again
    Registered User mattbolton's Avatar
    KS, USA
    208
    Here's the method I am using in a Script to export a RIB file:
    Code:
        obj = Mesh();
        while(obj)
        info(obj);
        obj = obj.next();
        obj = Light();
        while(obj)
        info(obj);
        obj = obj.next();
    Well, I am not using the info() function, but it serves to demonstrate that it's working.
    simply perfect
    thanx a lot
