Thread: 2018.0.7 / LightWave F10 render stuck in "Deforming Mesh" after a couple of frames
    Registered User Mr. Wilde's Avatar
    Jan 2006
    Germany
    195
    As the title says. I'm rendering 200 frames of a complex mesh deformation using nodal displacement. In LW 2018.0.3, Layout crashed with a BSOD every 20 frames or so. Now I upgraded to LW 2018.0.7, and the BSODs were gone. I rendered an entire sequence without any problems.
    I'm doing the entire sequence from a differrent camera angle now, but now the Renderer gets stuck in the "Deforming Mesh" stage every 20 frames or so. The app is still responsive (you can click "Abort", for example), but the rendering doesn't continue. Once I clicked abort, I can restart the render. Then it renders the frame it was previously stuck on just fine.
    Any ideas? Looks like a memory leak issue to me.
    Malmö, SWEDEN
    7,639
    Hmm... could be a memory leak. Have you tried this scene in LW2019?
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    Intel Core i7-4790K @ 4GHz
    16GB Ram
    GeForce GTX 1080 8GB
    Windows 10 Pro x64
    Jan 2006
    Germany
    195
    It's weird. It seems to happen depending on a camera angle. From other angles the sequences are rendered fine. BTW here's the result: https://forums.newtek.com/showthread...argate-Kawoosh
