Thread: No audio from a DDR bin
    Sep 2018
    San Francisco
    3
    Hi all,
    We are experiencing an issue where we are getting no audio from a specific DDR bin. The same clips, played in a different bin, same DDR, have audio. Does this make sense to anyone? Do bins have a "mute"?
    Thank you
    Have you tried looking in the audio mixer tab to see if the DDR is muted or volume turned down?
    Marty Jenoff
    TC-1
    TC 40 v2
    Canon c100, Canon XF305, XF205, XF105
    Focal Point Productions, Inc.
    Baltimore, Maryland
    www.focalpp.com
    19,327
    Quote Originally Posted by DannyAtZynga View Post
    Hi all,
    Thank you
    I assume by "bin" you are referring to a "MEM", one of the presets at the side of the playlist. Audio mixer configuration is per DDR, not per MEM, so that would not seem to be the cause. It IS possible to modify the volume level of individual clips in a playlist, though. Are you sure the clips aren't muted individually?
    Andrew Carlson
    Feb 2006
    Firth, Nebraska USA
    115
    Hi all,
    Thank you
    Be sure they are playing at 100% speed. Anything different will disable the audio.
    Jan 2015
    Los Angeles
    65
    We were having this same problem without even updating the firmware. Now we've updated the firmware and our TriCaster Mini is basically broken. All the switcher buttons are white. It's insane that you can' get help with a product that costs this much.
    19,327
    The white button issue means you need to update your nVidia drivers. There's probably a simpler cause for the audio issue, some setting or other... more detail might help.
