Results 16 to 19 of 19
Thread: Simple vector math is not simple
    Jan 2013
    NA
    74
    so if you use a different MDD Cache for Adding and Substracting
    using a copy of the node, this should work
    Thanks for the workaround, it works very well. This is very important for V11.6.3 user like me.
    What effect should I see?
    I tried ATM LW 2018.0.7.
    As Denis said, you saw the final effect as stage2 maybe you were on V2018, and I'm on V11, thanks for help anyway.
    7,876
    I think I found a workaround,
    the issue is caused by the second evaluation of the same MDD Cache node,
    one for Adding and then for Subsracting,
    in this case the node editor seems to miss/decal point iteration (?),
    using a copy of the node, this should work,
    note that it shouldn't use more memory,
    because it uses instance of the MDD file.
    What did you mean?
    Your node->Copy() function does something else than user can do manually picking up the all fields by himself/herself in UI (and making settings-equal version of node) ?
    If yes, that's very bad...
    LW uses node->Copy()/node->Load()/node->Save() internally to e.g. implement undo AFAIR..
    If you will put MessageBox() to node->Copy()/node->Load()/node->Save()
    you should see that they are called much more often than you expect..
    May 2006
    France
    3,959
    What did you mean?
    No, I meaned that older version had a limitation,
    node must be evaluated once only,
    for another operation of the same MDD,
    user need to add another node, or a copy.
    Denis.
    7,876
    Ah, right, because it had internal vertex index counter/"pointer", which is incremented each time Evaluate() is called to the next data.
    I had to use newer version, because could not see any bad effect. Therefor asked him to show screen-shot what he see. But now all is clear.
