Results 1 to 8 of 8
Thread: Power Charging Cable for electric Vehicle
    Registered User Rizwan's Avatar
    Aug 2005
    Huntsville,Alabama
    86
    Hi
    I am modeling a power charging cable for electric vehicles which will be flexible and have a form like the gasoline pump hose at any gas station. This cable will connect the charging station to the electric vehicle to charge its batteries. I used a disc to model this cable but when when I did that it does not have a free form and is not flexible. I would appreciate any tips or techniques to design this in lightwave. I am using LightWave3d 2018.0.6.
    Are you talking about for modeling or animation? For animation you want to model it straight and then deform it in Layout. For modeling you could actually do the same thing and the Save Transform it to freeze it.
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    Sep 2015
    Sweden
    554
    Build it straight like ernpchan said. Then, to deform it in layout there are lots of options but the easiest is probably to put a bone chain in it and use spline control to bend it as needed. The online documentation you get by hitting f1 should demonstrate how to do this. Just search for spline control.
    Male Modeler ccclarke's Avatar
    Mar 2006
    New England
    110
    Too bad Steve Worley's website was recently shut down. The Hoser plugin is perfect for this kind of animation. it would take two minutes to model and set up.
    7,884
    Quote Originally Posted by Rizwan View Post
    Hi
    Cable can be modeled using circle (sphere tool just in 2D),
    then make spline in 2nd layer,
    then use Rail Extrude, one layer profile, second layer curve.
    Then you can use curve to generate array of bones along it.
    Take a look at this video tutorial from Mark Warner:
    https://www.youtube.com/watch?v=aXpivTALS30
    Angry Mac User Otterman's Avatar
    May 2006
    England
    867
    I did use Spline Deformer from DP Kit. Made flexible hoses a doddle to work with. Not sure if its compatible anymore
    http://dpont.pagesperso-orange.fr/pl...l_Nodes_2.html
    Heres over 50 of them...
    Attached Files Attached Files
    http://dpont.pagesperso-orange.fr/pl...SplineDeformer
    very fine Otterman ..
    I had nearly forgotten this handy DP tool
    May 2003
    Ohio
    784
    Quote Originally Posted by ccclarke View Post
    Moved to http://www.worleylabs.com/
    I think there was a domain renewal issue or a transfer to the company now using worley.com
    The store portion is shuttered but you can still download demos. If you're desperate, you can still use the demo plugins with sample scenes. The only thing disabled in the demo plugins are the interfaces to make changes to the settings. However everything else is functional so that you can execute the sample scenes. Ambitious folk may attempt to configure settings by manually tweaking the LWS file in a text editor.
    If this refers to making wires in modeler, use this free plugin to make tubes.
    https://web.archive.org/web/20160322...&submit=Search
