Results 1 to 12 of 12
Thread: Still in 2015.3 ... Problems ...
    Scene Destroyer DrStrik9's Avatar
    May 2007
    Portland, Oregon
    1,684
    Unhappy Still in 2015.3 ... Problems ...
    I thought a project would be simple and quick, but I ran into a pretty serious dead-end.
    It's a logo with moving parts that fade in -- no big deal. But there is VOLUMETRIC lighting present. This SHOWS the faded out (100% transparency) parts, even though they're "faded out." :-( (I've done many projects with vol-lights, but NEVER with objects that are fading in while vol-light is present -- until today, that is).
    I can't even render two scenes and compose in AE because the objects need fading-in shadows WHILE they're fading in. It's a frigging BRICK WALL.
    Any advice? -- Thanks.
    May 2007
    Portland, Oregon
    1,684
    I see some old threads on this (vol-lights with transparency), and that it has been a problem for a long time. Does 2018 SOLVE it???
    Thanks again.
    May 2007
    Portland, Oregon
    1,684
    Wow. Something is VERY weird. NONE of the ENVELOPES are being saved with the scene file. This is repeatable. I have NO idea why. :-(
    Any ideas?
    Nov 2003
    jersey
    5,763
    2018 / 19... yes, you can use object transparency or just plain ol object dissolve, and the shadows cast into volumes shall fade away too. Be aware though, volumetric lighting is VERY different to old LW.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,129
    Quote Originally Posted by DrStrik9 View Post
    I don't get why you can't fade between two renders? Here's two renders on with only the light and one with light and object then just fade between them in AE. Usually faster to do it in post and also easier to change if there is changes needed.
    Done in LW 2015.
    7,884
    Did you try Object Dissolve instead of Surface Transparency?
    May 2007
    Portland, Oregon
    1,684
    Yes, THANK YOU, Sensei. Object Dissolve is the ticket! :+) Seems to WORK.
    May 2007
    Portland, Oregon
    1,684
    Well, dang it. I spoke too soon. Object Dissolve is "almost" better than good old transparency, but when it goes from 100% dissolve to 99.9% dissolve, the object POPS into the screen, with no volumetric shadows or object color, but it is CLEARLY VISIBLE inside the volumetric lighting. Crap. (The object color and vol-light shadows sppear as the object becomes more solid. But it really just doesn't work.
    The problem with rendering twice is that between dissolving in four objects at different times, and fading in the Vol-Light, it would be very tough to get it to look right.
    If someone could test this in 2018, I would be VERY grateful: Solid Volumetric Light, with objects dissolving from 100% to 0%, inside the Vol-Light effect. Let me know if you test it, and how it turned out.
    Thanks! :+)
    May 2007
    Portland, Oregon
    1,684
    @ Ztreem: Thanks for the test. Your sample looks great. My problem is that I have four objects, three of which are MOVING while fading in, all four fading in at different times. This is the first time I've ever tried to fade objects in while inside the Vol-light effect (making the issue very OBVIOUS), so I had never run into this issue before. I just can't imagine fading from one anim to another would be easy. It would probably need to be FOUR (or five?) anims (during fade only), one for each object. What a hassle. :-/
    7,884
    Attach scene and object, and we will be better able to help you playing with the settings and seeing what you are seeing..
    Jun 2003
    Sweden
    4,129
    Combining transparency and dissolve worked for me.
    Nov 2003
    jersey
    5,763
    Already said above, it works fine with either transparency or dissolve, but there are no volume lights, its a different way of working.
    RHN Nodal Tutorials
