Thread: Making a TriCaster be able to Stream on Microsoft Office 365
    May 2019
    Virginia by DC
    1
    My employer with 5,000 + employees now uses Office 365 which has web streaming capabilities. However, the TriCaster and Office 365 are not compatible. I was told by the great and fast service ticket people here, "Currently it is not possible to stream using Office 365. They have an RTMP server url, but no stream ID and that is required to get RTMP streams to work on the TriCaster."
    Is it possible to get this fixed? I am sure as more people and companies use Office 365 there will be more demand.
    As it is now I have to go through a HDMI/XLR to USB box (AV Bridge) which seriously downgrades the signal quality and feed a laptop that is running Office 365. Yes, it works, but it is very sad to see the beautiful images of the Sony BRC-H800 HD PTZ cameras on the TriCaster 460 program out monitor and then log into the stream on another laptop as an attendee and see the very 1990ish mediocre Y/C looking image.
    Thanks, James
    Apr 2008
    Racine
    1,570
    Hi James,
    Not familiar with Office 365, but can Office 365 use a webcam as a video source? If you are using the laptop to stream Office 365, perhaps you can run the free NDI Virtual Input app on the laptop and insert the TriCaster Program output into 365 via NDI? This would eliminate the AV Bridge setup and maintain quality, if it is supported.
    https://www.newtek.com/ndi/tools/#virtual
    Worth checking out
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Am researching what to do in our area with the same tools.
    Curious to see where this goes.
    Robert Wilson, MA Deaf Ed.
    Indiana Deaf School
    Sep 2014
    London
    91
    Copy and paste the following settings into the encoder of your choice:
    a. Server ingest URL: In your encoder, this may be called URL or Address. Microsoft Stream does not require a stream key or name, so you can fill this in with any non-empty value such as MicrosoftStream.
    taken from here https://docs.microsoft.com/en-us/str...-configuration
    so basically you could write wibble into the box and it would work. Equally you could write Boom-Boom-Pow-Mothers-Got-A-Brand-New-Cow
    Both would work.
    It's not a tricaster issue or a microsoft issue, it just requires a non-empty value, this seems to be a Microsoft thing. I've not tested, but I can see no good reason why it wouldn't work as documented.
