Thread: LiveStream Studio NDI and Tricaster...
    Feb 2014
    Shiloh, IL
    19
    Hey everyone,
    I have setup a workflow to offload steaming from the Tricaster 860 with AE to Live Stream Studio.
    What I have done is I configured NDI in Livestream Studio to take the SDI Camera Inputs from the Tricaster 860 and that works fine except when I have the Tricaster inputs connected in LiveStream studio the Tally lights on my cameras are always on even if I don't have that camera selected as live. When I shutdown LiveStream Studio the tally operations return to normal.
    Is this expected behavior for when you select a NDI Input source from the Tricaster? I suspected it was something with LiveStream Studio not sending correct tally information over the NDI protocol but their support organization is not interested in hearing that and are instead pointing to the Tricaster or my workflow as the issue.
    Apr 2008
    Racine
    1,598
    Can you please clarify the workflow? You said you want to offload streaming to LiveStream Studio, which would suggest the actual switching is taking place in the TriCaster, but it seems you are sending raw NDI camera feeds to LiveStream Studio as well. Could you not just send the TriCaster PROG feed to Studio via NDI if you just need it for streaming?
    I don't have experience myself with the tally light issue, but the more details you can provide, the better chance of a quick answer from someone. Which tally system are you using?
    And how many camera feeds go to Studio? Are you using the TC M/Es for anything? Try this - route each camera through a unique M/E and then select those M/Es as MIX outputs, and in Studio select those NDI MIX sources rather than raw camera feeds, curious if that would bypass the tally issue?
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    4,214
    Quote Originally Posted by kracklow View Post
    Hey everyone,
    Its a LiveStream Studio issue. We see the same thing in our events where we mix TriCasters and Studio setups.
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Panasonic UB300 4k cams
    Feb 2014
    Shiloh, IL
    19
    The idea is to have a separate mix suitable for Livestream versus more of a live IMAG mix for what is happening in the room.
    So we want to take all the Tricaster 860 AE inputs from the cameras and mix them separately. I can take the program out but that would be the same mix as what we have onsite. Which is often times not what we need for a Livestream.
    I have referred LiveStream support to this thread to try to get them to knowledge this issue.
