Results 1 to 15 of 15
Thread: Lightwave 3D 2015.3 64bit constant crash on Ryzen 2990wx
    Feb 2007
    Finland
    239
    Hi!
    I'm wondering if anyone else has come accross this type of problem. I got my new Ryzen 2990wx, with GTX 1060, 32 Gigs ram, Asus X399-E Gaming mobo. Everything is running smooth and fast as lightning - except for lightwave...
    If I have all 64 threads, and 32 cores active, and I start layout - open image editor - load image -> crash. Just quits to desktop. This happens on both Modeller and Layout, and sometimes loads image ok, but crash occurs every time when tweaking image contrast, gamma or any of the sliders. 100% crash every time.
    Anyway, the "fun" part is here - all the problems go away, if I park 8 cores, and run my Ryzen with 24 cores and 48 threads. Why might this be? I'm using Kray2 for rendering, and I can render a test bench scene I made with 64 threads - Since it doesnt have any textures in it, just materials.
    i would love to hear if anyone else is having the problem, or to let people know when working with 2015.3 or older, you probably won't get 100% out of your ryzen coz of this. To me, the solution of "go 2018 or 2019" is out of question since Kray2 doesn't support the new SDK.
    The problem is annoying, and I'm just wondering if it could be related to something else in my system and not Ryzen. I've run different benchmarks and memtests etc and everything seems to be fine. I also don't have any crashes or problems with any other software.
    Thanks guys!
    Westchester NY.
    43
    This is just from my own experience
    This sounds like a problem with your CPU communicating across memory controllers . If your using 8 sticks of RAM or more you can improve stability by
    - increasing the RAM voltage from stock 1.35 to 1.38 or more but not over 1.42. The RAM voltage is tied to the memory controller stability.
    - Set the VDD_SoC Voltage from auto to something above 1.1 but not over 1.2. This can help stabilize communication in a system with large amounts of ram and helps with communication between cores and memory controllers
    Running RAM above 2933MHz will require these adjustments and void the warranty on the CPU.
    Feb 2007
    Finland
    239
    Thanks! I am running 4 sticks of 8gb ram, 2666 MHz Kits, so not sure if that is the problem. Also No other program has any issues... Could it be that I have quite high latency ram (out specialist bought the components and they are not ryzen memory sticks but kingston valueram that is compatible with the mobo but not 100% sure about ryzen.
    Aug 2017
    Slo
    72
    First of all, I really don’t think my advise will solve the problem, but in such hopeless situations everything is worth a try. I would switch GTX with some kind of a professional GPU like Quadro and test again. In my experience, sometimes consumer GPUs do not work well with “exotic” CPU setups like yours. Not long ago, I threw away probably good working 2x8GB ECC RAM assuming it broken because the motherboard was occasionally reporting errors in a particular RAM slot. Only when it was too late to recover RAM I got that the errors were caused by GTX Pascal GPU. And in this HW setup Lightwave was especially vulnerable, crashed to the desktop almost immediately after all CPU cores began rendering.
    Aug 2017
    Slo
    72
    AND if I remember correctly, the crash thing went away if LW was using only 24 threads instead 32.... hmm.
    Feb 2007
    Finland
    239
    I haven't had yet a chance to change the graphics card, but I've tried other solutions and nothing is working currently. I'm kinda skeptical about the GTX being the problem, since there's no other issues other than LW 2015 crashing with textures. No flickering, stabile FPS on games, cinebench working, all GTX GPU benchmarks working like a charm... On the other hand I'm thinking maybe motherboard having some issues. I've had weird problem pop up when using cputemp monitoring. I leave the computer on, and I noticed my CPU temp spiked to 180 Celcius at some point. That cannot be, Idle it's running around 30-35 Celcius, and under hard long term stress (rendering) it's up to 65 Celcius tops. So I'm wondering what would cause the spike showing in the CPU temp "max temp" as 180 celcius? Maybe it's a bug in the monitor software, or maybe it's a bug in motherboard? Or maybe faulty CPU? No crashing or anything else, suspecting motherboard gives wrong temps or similar. I haven't witnessed the 180celcius my self, it happened during my computer being idle on desktop for around 30-50 minutes.
    7,875
    Try trial of LW 2018 and then trial LW 2019, just to see whether it crashes or not in exactly the same situation, like on LW 2015.3.
    There is no sense answering "what it might be" if problem that you're experiencing is already solved by Newtek developers in newer LightWave version.
    If it works with 48 threads, you must stay use 48 threads, and forget about 64 threads..
    Feb 2007
    Finland
    239
    2018 and 2019 work great. Also the cores and threads dont make sense since I have 72 thread dual xeon at the office (3 of them) and they have no problems. Also this problem is now confirmed with identical system from my co-worker. She has exact same system and producing same crash. Anyway, going from a point that I cannot currently go to 2018 or 2019 because Kray2 support is none. Would love to hear if any other 2990wx users have the same problem or does lw2015.3 work well In some, that might narrow it down. Its sad that it dont work, since its 10% faster than our almost double priced xeons at the office.
    Registered User Oldcode's Avatar
    Jan 2004
    Boston
    388
    Quote Originally Posted by next_n00b View Post
    AND if I remember correctly, the crash thing went away if LW was using only 24 threads instead 32.... hmm. AND if I remember correctly, the crash thing went away if LW was using only 24 threads instead 32.... hmm.
    I just built an AMD Threadripper 1st Generation 1950x with 16 cores and 32 thread. I've had no trouble with Windows 10, Lightwave 2015.3. Have not tried 2019 yet.
    7,875
    Quote Originally Posted by Pheidian View Post
    You can always run two instances of Layout or LWSN at the same time, with half of threads each set in the preferences. They will use full power of CPU together during final rendering.
    Feb 2007
    Finland
    239
    Well the problem is, that if I run Ryzen with all threads active, and disable them in Lightwave or otherway (affinity) - it does not make any difference, crashes anyway.
    Aug 2017
    Slo
    72
    Quote Originally Posted by Oldcode View Post
    My issues were all related to the buggy drivers for 1070Ti on win7 HP Z620. For more than a year I struggle with this GPU in dual Xeon setup. If I took 1 CPU out (CPU riser) than everything was fine. Prior to that everything was also fine with 1060 and dual Xeon (Both are Asus Strix). So I thought why not 1070Ti then, and that was a crash-fest. HP also recommends Quadro in their workstations. You better not even think about calling the support about some issues if you don’t have Quadro in WS.
    7,875
    So when you said "activation of cores" you meant some Ryzen option, not LightWave options controlling multi-threading?
    I think so you might be better kind of answers on some Ryzen forum.. Maybe people there experienced some kind of troubles with other software as well, and have ready solutions.
    On Windows you can control on which CPUs each application in run using Task Manager > Set Affinity.
    If you have set it to one it's also crashing? Two? etc.
    Feb 2007
    Finland
    239
    Yes, and the really weird part is, what I forgot to mention, is that Ryzen has Simultaneous Multi Threading, which means that when it's on, 32 cores provide 64 threads. When it's off, you get only 32 cores and 32 threads. What makes it even more fancy, is Lightwave 2015.3 works without crashes if I turn off the SMT, so I have all 32 cores, but only 32 threads running. Also SMT is not the actual culprit, since I can run 24 cores with SMT on, having 48 threads. But If I have all 32 cores on, and SMT on, with 32 cores and 64 threads, the crash happens every time all the time.
