Results 1 to 10 of 10
Thread: IsoCorder file no good
    Jun 2006
    Chicago, IL
    505
    I've attempted to record a NDI stream using IsoCorder (latest version, just downloaded). I can see the stream just fine in both IsoCorder and also Studio Monitor.
    However, the MOV file it's generating isn't viewable in ANYTHING except the old, unsupported QuickTime player. When loading that file into Premiere CC (v13.x) it says the video streams can't be decoded but it does get the audio side. Won't display in VLC either.
    Is this a bug in IsoCorder?
    Any thoughts?
    Thanks!
    Fritz Golman
    Apr 2008
    Racine
    1,594
    Hi Fritz,
    Should be an XDCAM codec, make sure those are installed
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Jun 2006
    Chicago, IL
    505
    Hi Fritz,
    Jeff
    Jeff,
    I'm using Premiere Pro on a Windows machine. Have used XDCAM before, many times. And, Adobe is supposed to have native support for MOV files, which is the container.
    What am I missing here?
    I'm not even sure how that codec would be gotten/loaded.
    Fritz
    Use MediaInfo to check what the Codec ID of the file is. It should be XDCAM (xd5*) unless this is a very old version of IsoCorder, then it might be SpeedHQ.
    https://mediaarea.net/en/MediaInfo
    If you have a SpeedHQ codec file (SHQ#), you can use the TriCaster export tool to convert it into ProRes or this tool that can convert it into something Premiere can read.
    http://dl.strm.one/ffmpeg-gui/
    Key Accounts Sales Engineer
    Jun 2006
    Chicago, IL
    505
    Kane,
    I think that there's something the matter with the current version of IsoCorder (just downloaded).
    It appears that it is NOT recording as an XDCAM codec but some flavor of MP4.
    Here's what MediaInfo spat out from the file I just recorded:
    General
    Complete name : C:\Users\1123781\Videos\REC 1.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 0000.02 (qt )
    File size : 22.2 MiB
    Duration : 16 s 379 ms
    Overall bit rate mode : Variable
    Overall bit rate : 11.4 Mb/s
    Encoded date : UTC 2019-05-01 17:47:40
    Tagged date : UTC 2019-05-01 17:47:40
    Writing library : Apple QuickTime
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : [email protected]
    Format settings, BVOP : No
    Format settings, Matrix : Default
    Format settings, GOP : N=1
    Codec ID : m2v1
    Source duration : 16 s 383 ms
    Bit rate mode : Variable
    Bit rate : 8 148 kb/s
    Maximum bit rate : 25.0 Mb/s
    Width : 480 pixels
    Height : 360 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 29.970 (30000/1001) FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 1.573
    Time code of first frame : 12:47:23;29
    Time code source : Group of pictures header
    GOP, Open/Closed : Closed
    Stream size : 15.9 MiB (72%)
    Source stream size : 15.9 MiB (72%)
    Language : English
    Audio
    Format : PCM
    Format settings : Little / Signed
    Codec ID : in24
    Duration : 16 s 368 ms
    Bit rate mode : Constant
    Bit rate : 2 304 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Bit depth : 24 bits
    Stream size : 4.50 MiB (20%)
    Language : English
    Other
    Type : Time code
    Format : QuickTime TC
    Time code of first frame : 12:46:53:06
    Time code, striped : Yes
    Language : English
    I think that there's a bug in IsoCorder if it's supposed to be XDCAM. I would assume that the issue is that QuickTime container with an MP4 codec is somehow not recognized by anything in Windows?
    Note, in this case I was picking up an SD stream from YouTube (via VLC NDI integration). However, results were the same in other standard HD formats (EG, 720p, 1080i).
    Please advise.
    Thanks!
    Fritz Golman
    Aug 2015
    london
    226
    Quote Originally Posted by fgolman View Post
    Kane,
    General
    Format : MPEG-4
    Video
    Format : MPEG Video
    Codec ID : m2v1
    Please advise.
    Thanks!
    Fritz Golman
    That shows MPEG2 codec video in a Quicktime Movie container, which is basically XDCam HD (in MOV). If its not HD then its potentially MPEG2 SD - which is pretty much XDCam or some other basic variant of MPEG2.
    The MPEG-4 'format' is just a semantic - in fact the MPEG4 container standard is derived from QuickTime, and so its basically 99% the same DNA. Its not showing an MPEG4 *codec* but m2v1 which means MPEG2. Not entirely familiar with MediaInfo's output but if "GOP : N=1" means iFrame then its probably traditional SD XDCam CBR
    It's true that you might expect Premiere to read this natively, so perhaps something is up, but its nothing to do with MPEG4 *codec* per-se , although the pixel size is non-broadcast - so that could be a clue since its a deviation from 'straight' XDCam SD.
    Jun 2006
    Chicago, IL
    505
    So, what's the bottom line on this?
    I'm trying to edit in Adobe Premiere CC in Windows and it won't recognize the file properly that comes from IsoCorder.
    I'm trying to avoid the time to cross covert in some tool.
    Is there a plug in missing in Premiere?
    Fritz
    Look at the resolution, it is 480x360, its not even SD resolution. The compression is MPEG-2 (m2v1) however, Adobe Premiere will not decode files tagged as m2v1 (see attachment). I do not know how you even got a file at this resolution to start with.
    NewTek Recording Formats.pdf
    Jun 2006
    Chicago, IL
    505
    Gotcha. This was a live recording from YouTube via VLC/IsoCorder. However, it's IsoCorder generating the m2v1 file.
    I think I have a better way of attempting to do this rather than streaming VLC and recording separately … record directly within VLC.
    Fritz
    That explains it, I though it was coming from TriCaster, but if the YouTube clip was only 360p, then that is what IsoCorder will record.
