Results 1 to 15 of 29
Thread: DOF Noise
    New York City
    288
    DOF Noise
    Got an issue with DOF. I'm not sure if it's sub pixel issues or something else. I can get it out of my render without DOF but not with it. I've tried increasing the light samples, camera samples, despike, denoise and various other brute force techniques. But nothing seems to work Click image for larger version.
Name:	1400 dof noise.jpg
ID:	144843Click image for larger version.
Name:	1401 no dof.jpg
ID:	144846Click image for larger version.
Name:	1400 no dof.jpg
ID:	144845Click image for larger version.
Name:	1401 dof noise.jpg
    Any ideas? Thanks
    Nov 2003
    jersey
    5,759
    Thats a reflective surface, yes? Looks like that's where the noise comes from. Look at the raw RGB buffer, with dof on and turn up camera samples till thats satisfactorily smooth, then look at the spec buffer(s) with dof off and turn up reflection samples till thats acceptable. Also be sure to bring your recursions down as low as you can get away with.
    There're a few things be aware of balancing cameras, lights, reflections, etc in the new renderer. you might find the tuts linked in the sig helpful to get yourself into optimal results territory.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    England
    5,810
    Any chance you could post your render settings? Just wondering what your sampling settings are for:
    Camera
    Reflection
    Adaptive Sampling Threshold
    Looks to me like camera sampling issues, but it's difficult to tell. Also, reflection samples look like they're too low. For DoF, cam samples might need to be up to 64 or 128 to get rid of moderate noise. (Or even higher for lots of noise, or cleaner noise.)
    When using DoF though, as it requires lots of camera samples, it means you can potentially reduce other areas of sampling, like reflection/SSS/refraction etc.
    Also, are you using an environment light? Or GI?
    Desk Work:
    Desk Home:
    New York City
    288
    Thanks everyone. Rebel Hill, I've got your tutorial and am working my way though it. Very helpful, but a lot of it uses environment lighting or HDR lighting. I'm not using GI as this is animated and am just using a studio'ish lighting set up. Here's some of the settings I've tried.
    Camera tried Samples 1-8 , up to 1-32 and 3-32
    Tried :Adaptive Sampling Threshold .08 to .01 and also .03
    Reflection 6
    Refraction 6
    Subsurface 2
    2 Area lights
    the one called area samples 16 up to 32
    the called side (which doesn’t hit the wall) 4 to 16
    there’s also two spot lights in the scene which are excluded from everything except the eyes.
    Thanks for the suggestions and I'll give them a try.
    Nov 2003
    jersey
    5,759
    HDR, enviro, regular lights... no difference, the renderer always works the same for all these types.
    But trying these samples here, those there, shooting in the dark will get you nowhere (at least not fast)... check the "Sampling workflow" video... there's a straightforward workflow that works on every single scene, no matter the contents or lighting.
    RHN Nodal Tutorials
    "Camera tried Samples 1-8 , up to 1-32 and 3-32
    Tried :Adaptive Sampling Threshold .08 to .01 and also .03"
    Had DOF problems recently, took MIN SAMPLES up to 64 (which overrode the max samples which i left at 9) this worked better than light or reflection samples tinkering at canceling out noise, enviro light is not same as other lights as its calling on the BG or whatever HDR you have loaded and it is more affected by radiosity and prone to noise
    New York City
    288
    Well, I thought I had gotten it. But no. Here's the settings I tried and it's better but still there.
Name:	Render Settings.jpg
ID:	144851Click image for larger version.
Name:	Camera Settings.jpg
ID:	144852Click image for larger version.
Name:	Area Light Settings.jpg
ID:	144853Click image for larger version.
Name:	Side Light (Area) Settings.jpg
ID:	144854Shot 07 Render Test 01.mov
    - - - Updated - - -
    Quote Originally Posted by gerry_g View Post
    Thanks, I'll ry it. But I'm not using GI or envio lighting. Just two area lights and two spots only on the eyes.
    - - - Updated - - -
    Thanks, I'll go look for it. I know it's on one of drives here somewhere, hmmm
    New York City
    288
    Found it. Watching now.
    New York City
    288
    OK, the video helped and I was able to get my render time from 6m to 1.5m with the same quality. But still have the same problem. It's in the Specular Direct buffer is where I see the issue. The alpha and depth buffers are all white and the reflection buffer is all black. I'm down to just one area light lighting the scene and am slowly increasing the samples. Thanks again.
    Nov 2003
    jersey
    5,759
    No worries... in which case it's mostly gonna be your reflection samples that you want to turn up... for ease, do it without DOF enabled, so you can see just the results of the spec noise, then back on, and up camera samples if noise returns after adding the DOF. And yes... in my vid I show the alpha buffer as an "easy view" for checking the DOF noise, obvs in your scene, the whole screen is occupied, so you can use the RGB, raw colour buffer instead in the same way.
    RHN Nodal Tutorials
    Nov 2003
    jersey
    5,759
    Oh, btw... I notice in your screenshots that your lights arent visible to camera... so what's being reflected in the shiny surfaces? Are you by any chance using luminous geo, because if so... don't. Lose it, and make lights visible.
    RHN Nodal Tutorials
    New York City
    288
    Yes, I fopund that some of the geo was luminous. It came in that way and I didn't catch it. However there might be some others. I didn't realize that I should make the lights visible to camera. Thanks
    Nov 2003
    jersey
    5,759
    You make the lights visible to make them appear in reflections too, rather than using lum geo standins like old days. The old days way will make things sad.
    See vids 22 and 35 for more details.
    RHN Nodal Tutorials
    New York City
    288
    will do, thanks again.
    New York City
    288
    Got it looking good with no DOF. But still having fun with DOF.
