Thread: import vertex color
    Super Member dblincoe's Avatar
    Aug 2004
    Springfield, Missouri
    818
    import vertex color
    Does anybody know of a way to import vertex color into LW (preferably 2015 or 2018) from zbrush?
    7,857
    Quote Originally Posted by dblincoe View Post
    My old plugin TrueOBJImport does that.
    http://www2.trueart.pl/?URIType=Dire.../TrueOBJImport
    I made adjustments for one of clients to support this mode.
    If you're interested, then send me test object exported from Z-Brush with vertex color maps, and registration info from reg info like during previous purchases from you.
    It will speed up process.
    Aug 2004
    818
    Thanks Sensai, I need it for mac but have another route. I can polypaint and convert to texture. Then goz to lw. In lightwave I can use apply texture to vertex map plugin.
    only downfall is it is not automatic on import. A little timeconsuming for multiple meshes from zbrush.
    7,857
    Send me test object in .obj file format to my e-mail anyway. I will check whether this feature is still working. It was made 10 years ago after all..
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,125
    If zbrush has support for the .ply format you can test that, it has vertex color support.
    maybe this is something that could work.
    http://www.zbrushcentral.com/showthr...for-ZBrush-4R8
    Here's another method going through meshlab.
    https://polycount.com/discussion/117...o-vertex-color
    Aug 2016
    a place
    1,683
    is there a way to see vert cold in lw/modeller?
    7,857
    Just click on "Apply to surface", and it'll add Color Vertex node to surface Node Editor, like here:
