Thread: Lightwave 8 Native Liquid Pour and Fill
    Registered User 3dhotshot's Avatar
    Mar 2009
    Durban
    214
    Can somebody explain how this is done so perfectly ?
    water is clothfx i guess
    splash is particlefx
    the pour is just animated geometry
    most probably.
    Jan 2005
    Colorado Springs
    1,760
    Yes, I think erikals is right, although I think the water in the pan is just a high-density subpatched mesh animated with a combination of a Turbulence, Rings2 and DistanceToObject Gradient displacement map.
    mTp
    yes, could be
    these days one'd use Hurley Up, or similar
    14,557
    The actuall pouring looks like geometry ..maybe morphed or weight map animated, then itīs just 3 particles spurting up, super easy to do, and the water effect looks like just displacement, no need for clothFX, with the right procedurals that can be acheived, but it could also be clothfx as erikals says, so I am all good with erikals description.
