Thread: Turn off the Hub guide for Mac?
    London
    2,333
    I’m tired of the constant crashing and told that -i is the key to turning off the Hub, but can’t find any references on how to actually do it!? I know it involves some Terminal commands - does anyone have a simple step-by-step on how to do this on a Mac? I think many people would find it useful!
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,671
    Hi Mark. I found this thread: https://forums.newtek.com/showthread...2-Turn-Off-Hub
    Post #6 seems to be the one with the info on how to do it.
    Hope it helps
    May 2003
    Ohio
    778
    More directly, see the ReadMe.txt file that installs in the Lightwave program folder. Then search for the section: "OS X: Running Without the Hub"
    London
    2,333
    Thanks all. The renaming of Hub just results in a crash now. I’ll check out the Read Me again, I’m sure i was left scratching my head. If I get it sorted i’ll slap it on YT for others as it shouldn’t be this hard!
    London
    2,333
    Sorry this took so long but good news. It looks like just renaming the Hub (ie "_hub") now works in 2019.03. I'm sure previous versions just crashed Layout but all seem to be happy. Slightly getting my head around a change on workflow but not having crashes
    May 2003
    Ohio
    778
    With the last failed attempt to rename Hub, did you restart your computer?
    It is possible there were active processes interacting with Hub when it was last renamed. Restarting the computer would clear all that out.
    London
    2,333
    Just did a restart to check... all is running Hub-less
