Thread: Console rendered in native 2019
    Here is a little console that I did the other day. Render time @3600 x 3600 was a respectable 33min.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    May 2012
    Virginia
    374
    It looks really great, Tim! The soft shadows and lighting looks very good.
    If I was going to nitpick, it would be the vases with the flowers; the vases look like they need some roughness and a texture (perhaps turbulence or some fractal noise).
    I would also consider adding a texture map to the flowers, dropping their spec to zero, and adding some light yellow subsurface.
    It's not a big deal, but to my eye they look a bit out of place in the scene.
    Quote Originally Posted by RPSchmidt View Post
    Thanks for nitpicking! It makes us better artists. Yeah, the flowers come off like plastic, I should have adjusted that. I did add scratches to the vases but they could probably use some slight waviness to the geo as those vase are never perfect.
    Thanks!
    Tim Parsons
    Technical Designer
    A.K.A "The Silver Fox" Gungho3D's Avatar
    Aug 2009
    Oztralia
    404
    Love the render, but yep: maybe some more TLC on the flowers.
    Plus, unless this is the intended "artistic shot," maybe a more interesting angle/angles? ...
