Results 46 to 60 of 63
Thread: A Couple of Basic Lightwave Questions Please
  1. #46
    14,438
    Quote Originally Posted by Shabazzy View Post
    Wow.
    If I didn't see it, I wouldn't have believed it.
    You've shown me something that I didn't think was possible.
    Sir, you have my thanks.
    It must be new and something changed in 2019 eps importer, tried it in 2015.3 and it doesnīt work.
    Then I just recently saw this vid..and then I tried 2019.0.3
    It didnīt work the first time I tried, in fact it would only crash, but I wasnīt doing exactly what xswampy did..I namely forgot to use a layer in inkscape, and had previously been drawing without any layer.
    Once I made a layer first and traced a bitmap logo, saved out as eps...it now works in 2019, but not in 2015 it seems.
    Thanks for the showcase Xswampy.
    So the fact that I just recently upgraded to 2019...explains why I thought eps was out of the question with inkscape.
    With this ..I really do not see any huge need for illustrator, if it werenīt for the lack of filleting rounding of paths in inkscape.
  2. #47
    14,438
    I do get a lot of crashes though with importing eps to lightwave with inkscape..even if i make layers first.
  3. #48
    Mar 2009
    Dayton, OH
    58
    Thanks again for your help.
  4. #49
    Mar 2009
    Dayton, OH
    58
    How do you change the grid size in Modeler 2018?
  5. #50
    Mar 2009
    Dayton, OH
    58
  6. #51
    Dec 2009
    London, England, UK
    992
    Blog Entries
    18
    Quote Originally Posted by stevedross View Post
    You just zoom in and zoom out with the magnifying glass in the top right corner of each viewport or press the comma or fullstop keys to zoom in and out. If you look at the grid size indicator in bottom left of the Modeler window you'll see the grid size change.
  7. #52
    Jan 2005
    Colorado Springs
    1,735
    I use the comma and period (fullstop) keys as Shabazzy mentions, but I mostly hold ALT and CTRL and mouse drag right to zoom in and drag left to zoom out, positioning the cursor where I want to zoom to. The Display Options (d) Units tab allows you do determine how often the grid size changes as you zoom:
    So, with the setting shown of 1 2 5, as you zoom in the grid size will change from (for example) 50cm to 20cm to 10cm and then 5cm, 2cm and 1cm, etc. and zooming out goes up in these same intervals.
    RE: the ALT-CTRL-drag to zoom, I also use the ALT-SHIFT-drag to slide the viewports, and ALT-drag to rotate the Perspective view.
    mTp
  8. #53
    Mar 2009
    Dayton, OH
    58
    This is the last question for (today).
    Back in the old days, I would just render everything out as an animation.
    What's the process for doing that in 2018?
    Thanks as always.
  9. #54
    Ohio
    716
    The process is the same as always. Render as image files (not video animation) and then compile into video.
    Recent discussion:
    https://forums.newtek.com/showthread...r-has-no-image
  10. #55
    Mar 2009
    Dayton, OH
    58
    No way to render it out as an animation anymore?
  11. #56
    Ohio
    716
    There is always a way to render out as an animation video file. And there is the same reason not to render to a video file.
    What happens when you've been rendering for 12 hours and then there's a fault that destroys the video file?
    That's why rendering to still images (JPG/PNG/TGA/EXR/etc) is the sensible way to render animation. Then smack those images into a video file.
    DOCS: https://docs.lightwave3d.com/lw2019/...with-rendering
  12. #57
    It just isn't safe. Still possible in 2018 -19.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
  13. #58
    Registered User MarkAH's Avatar
    Feb 2008
    Green Valley, AZ
    63
    Back in the old days, I would just load my film cassettes into the Scopitone.
  14. #59
    Super Member tburbage's Avatar
    Redwood City, CA
    361
    I tried saving a four letter text as an EPS in Photoshop and Lightwave tells me "unknown file format" and "Not recognized by this file converter".
    Is there a proper way of saving it out of Photoshop other than just esp so it will convert?
    After converting the text in Photoshop to outlines, use File > Export > Paths To Illustrator, specifying the name of the path. You can save to either .eps or .ai extensions. EPS Loader in Modeler can load that just fine (it doesn't care about the extension). I get good results specifying Spline Curves or Closed Polygons. Auto-AxisDrill worked for me in cutting out the "holes" in some letters.
    After converting the text in Photoshop to outlines, use File > Export > Paths To Illustrator, specifying the name of the path. You can save to either .eps or .ai extensions. EPS Loader in Modeler can load that just fine (it doesn't care about the extension). I get good results specifying Spline Curves or Closed Polygons. Auto-AxisDrill worked for me in cutting out the "holes" in some letters when working with Closed Polygons.
  15. #60
    Redwood City, CA
    361
