Results 1 to 10 of 10
Thread: Alpha and UV: yellow surface is rendering black?
    Registered User rdolishny's Avatar
    Peterborough, Ontario, Canada
    313
    Unhappy Alpha and UV: yellow surface is rendering black?
    As you can see in the screen capture here, I've added a PNG with alpha channel and it looks great in Modeler, in OpenGL in Layout, but not in VPR or with an F9 rendering. Then, my creamy yellow avocado is solid black when rendered.
    I'm playing with the image in image editor and by toggling Invert Alpha I can see the alpha channels seem to be in Lightwave, except when its' time to render.
    For the record this is my FIRST 2018 project after upgrading from 11.6. So I have a lot to learn. Why is my image looking good in Modeler and Layout OpenGL but when it renders it's black?
    313
    Now I'm getting even more confused. I found an option for background colour which makes no sense as my happy face is just black ink on a transparent background. But sure enough, when I selected a colour my face changed to that colour blowing away my creamy avocado texture!
    All I want is my happy face over my creamy yellow beautiful texture.
    Jan 2005
    Colorado Springs
    1,761
    If you press F6 to bring up the LW Image Editor, does the PNG file show as having an Alpha channel? The 3rd party Image Editor I use (Corel Photo-Paint) will write PNG files, but it doesn't seem to save the "Mask" I create as an Alpha channel in the PNG file. I use TGA files, and the mask I have in Photo-Paint works as expected.
    mTp
    Aug 2010
    Kernow
    2,057
    You need to make two materials... one yellow & one black. Then you use your b/w face image as the input to a material mixing node.
    or you can just use a gradient which may be quicker
Name:	Screen Shot 2019-04-07 at 19.08.09.png
    313
    Quote Originally Posted by XswampyX View Post
    This was it. Thank you very much.
    So, this being my first LW 2018-19 project... this is just the way it's going to be now, correct? The days of adding a PNG with alpha are over? Not hating, just want clarity.
    On a somewhat related note, I can't get rid of this super over-exposed look. Do I play with lights, or surfaces somewhere else?
    Nov 2003
    jersey
    5,759
    Yknow, you couldve just set your background colour in the image node to the yellow.
    This is how it is in nodes, because when you plug a node into the colour input, you're setting the entirety of the surface colour and thus overriding/replacing whatever you had in the basic colour swatch. Thus, to have an alpha'd image over a colour, you do that in the node(s) itself before plugging to the material colour input. As for the exposure look... either/both, it depends.
    There's plenty good stuff on both working with nodes and the renderer at the links in the sig.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    313
    Thank you RebelHill. I found your YouTube page with nodes walkthroughs. Is this the library that was once for sale? Or is there more if I buy it from Liberty3D. Because, I think I'll be putting on a coffee and working through this archive, now. I can't put this off any longer.
    Nov 2003
    jersey
    5,759
    Like all the other training, there's the free foundations section, and the full thing is available from the links in the sig. As the exchange rate currently stands I *think* its cheaper currently bought in £ off my site.
    RHN Nodal Tutorials
    313
    Purchased. Thank you everyone.
