Thread: GPU deNoiser malfunctions in renderSequence
    Hi Guys,
    I am rendering a sequence of more than 100 frames. Hi Res, but low Quality lights. To pretty up the picture a little, I activated the GPU denoiser.
    Well ... the first 13 to 32 go well, and all of a sudden, while the render preview is still ok, the output files (png32) are turning 100% black. Then, after 10-20 frames, one frame is saved correctly, but afterwards everything is black again.
    This is very frustrating. Anyone of you experienced similar problems?
    Or have you rendered a sequence with gpu-denoise turned on without any problems?
    thanks in advance
    Wolfgang
    Pessac
    5,028
    Like the documentation says: " Only works for still images (not network rendered) and requires an Nvidia Geforce, Quadro or Tesla graphics card with at least a Kepler chipset. There are no user-configurable options"
    B
    LightWave 3D Trial Edition
    AMD Threadripper 1950X, Windows 10 Pro 64-bit, 32GB RAM, nVidia GeForce GTX 1050Ti (388.13, 4GB and 768 CUDA cores)
    Note to myself: There are times, you should read the manual.
    thanks for pointing that out!
    Wolfgang
    Pessac
    5,028
    Hey Wolfgang,
    Like you found out, it certainly can work, but it's more likely not to.
    B
    Jan 2005
    Colorado Springs
    1,739
    FYI, I rendered 140 frames this morning in LW2019.0.2 using the GPU de-noiser with no problems. No all-black frames at all. The green bar in the Render Status window indicated the de-noiser was applied to each still image comprising the sequence. I used TGA24 files rather than PNG files.
    mTp
