Results 1 to 10 of 10
Thread: Unable to see my NDI SCAN CONVERTER in studio monitor and tricaster
    Feb 2018
    Chartres
    4
    Hi all,
    I use NDI Scan Converter (NDI Tools up-to-date) on many pc (windows) but on one pc, i can't see my source neither in "Studio Monitor" nor my Tricaster.
    All my pc's are on the same network, i tried with "pattern generator" and i can find my source in "Studio Monitor".
    Do you know where is the problem?
    Thank you!
    Quote Originally Posted by boomker View Post
    Hi all,
    Thank you!
    I take it you can see the NDI Scan Converter selection, but when you choose it you get nothing?
    Is this a laptop? Many laptops have dual GPU's and you might have to force NDI Scan Converter to use one GPU or the other. For example, my laptop has both a Intel and nVidia GPU. I have to force NDI Scan Converter to use the Intel GPU to see the image, if it goes to the nVidia then I get nothing.
    Key Accounts Sales Engineer
    Sep 2005
    NewTek
    1,685
    I would also make sure that your network location is set to private on both PC's if its set to public on either device you won't get video but you will be able to discover the source.
    Zane Condren
    NewTek Inc.
    new.tk/call
    Feb 2018
    Chartres
    4
    HI,
    First, thank you for your respond.
    So i can launch NDI Scan Converter, choose the framerate etc... but i can't find my "Scan converter" in studio monitor, I do not see it in the list of sources...
    It's not a laptop, i already try to force NDI Scan Converter to use GPU but i can't find the option "Preferred graphics processor"...
    I tried to change "Physx" setting to force my GPU but that does not change anything.
    I don't understand why "NDI Pattern Generator" is working but not Scan Converter...
    I will try to set network location to private but, how can you explain why pattern generator is working ?
    Ty and sorry for my bad english!
    Apr 2008
    Racine
    1,596
    Latest NDI Scan Converter version requires Windows 8 or 10, not compatible with Windows 7 but I don't know if maybe it would still run but just not work correctly?
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Jeff
    It shouldn't even install the new NDI Scan Converter on Windows 7 systems.
    Feb 2018
    Chartres
    4
    Jeff
    Hi, I am on a Win10 up-to-date... I try the network setting (private etc...) but Scan Converter don't work..
    Ty
    Apr 2016
    Lisboa
    25
    Ty
    Do you have a laptop with Intel + nvidia GPU? Try to force running Scan Converter with Intel Graphic and see if it works.
    Feb 2018
    Chartres
    4
    Quote Originally Posted by rsilva View Post
    Sorry for the response delay.
    I already try to force Scan converter to run with intel graphic or nvidia.
    I dont understand why it doesn't work. And why "NDI Pattern Generator" work ...
    Ty
    Apr 2019
    uk
    1
    Hello
    I have the same problem: when I'm running scan converter, I get "No NDI sources found" on the virtual input and studio monitor.
    The test pattern generator works as expected (I can view the test pattern image on another PC).
    To clarify: I'm not getting a blank screen showing up through NDI, its that the source just doesn't seem to be sent over the network.
    Both machines I'm trying to use are running windows 10.
    I think it might be because I have a very old GPU (geforce 200 series), but the system requirements page for NDI tools doesn't seem to have a GPU requirement (the main reason that I'm trying to use NDI tools is that my GPU doesn't support the windows 10 game DVR, and other recording software has too big a performance impact, so I thought I'd try using two old PCs together).
    Overall I'm trying to game on my desktop and use scan converter, virtual input and OBS studio to record gameplay on my laptop, because recording directly on the desktop loses too much framerate.
    Any ideas?
