Thread: Open GL issue LW2018
    Oct 2013
    UK
    34
    Hello:
    Mapped textures have stopped showing up in open GL in layout.
    Any ideas as to why this might be happening?. It was working fine and suddenly it was gone. Can't remember exactly what I was doing when it happened.
    Uninstalled LW and reinstalled (didn't erase config files) and issue is still there.
    Textures show up in modeller fine.
    It renders fine, it's jus the Open GL preview. The option is checked in the Open GL options tab.
    Mac OS 10.10.5 Latest LW2018 build.
    Thanks,
    Sep 2015
    Sweden
    500
    Is a material with the textured color connected to the gl output in the texture node editor? I have accidentally disconnected them before and lost textures in gl view. Try connecting the color output of the texture node to a standard shader and then connect that to gl only. You can leave everything else where it is so you don’t mess up your proper rendered material.
    ack ack Markc's Avatar
    Feb 2006
    England
    1,295
    Change the Shading Method in the GL prefs panel to PBRGLSLShaders.
    Mac Pro (2010) OSX 10.13 RX580 Pulse LW2019
    Oct 2013
    UK
    34
    Hi it's just simple texture maps loaded into the image node which is itself connected into the color input of the material node. The simplest of all nodal arrangements. It is not one texture that has disappeared from view, it is all of them, so I am seeing a lot of white-ish polygons in the layout viewport when choosing "textured solid shaded wireframe" mode. VPR is fine, renders are fine as everything shows up.
    I am in the middle of a deadline so I'll investigate further later on when I am finished. Thanks for your suggestion, I'll try.
    Oct 2013
    UK
    34
    Hi thanks, It was already selected, so tried the other options and then back to it but nothing happened. The issue isn't a game stopper it's just a slight inconvenience. I'll try to sort it out once I render all the images. Thanks for your help.
    Pessac
    5,015
    You can use the OpenGL input on the Surface destination node to have something display. Have you got something attached there by mistake that is overriding your display?
    B
    LightWave 3D Trial Edition
    AMD Threadripper 1950X, Windows 10 Pro 64-bit, 32GB RAM, nVidia GeForce GTX 1050Ti (388.13, 4GB and 768 CUDA cores)
