Thread: Surface Material Transition Animation LW 2018
    Aug 2008
    Largo Florida
    21
    Hello...
    I'd like to be able to change surface colors/materials of an object over time.
    I'm sure that LW can do it, but how?
    7,769
    To change one material to other material you can use Material Mixer. It takes Alpha parameter as input (from e.g. Vertex Maps > Weight map node), or you can use Envelope editor.
    LightWave Plugins
    Pessac
    5,018
    If you use the PBSDF material, you can also set envelopes to change the surface properties over time - make your object metallic, plastic, skin or glass, etc.
    B
    LightWave 3D Trial Edition
    AMD Threadripper 1950X, Windows 10 Pro 64-bit, 32GB RAM, nVidia GeForce GTX 1050Ti (388.13, 4GB and 768 CUDA cores)
