Results 1 to 8 of 8
Thread: Rectilinear HDRI environments in Lightwave?
    So Ive always used Lightwave Image World in the backdrop tab to wrap a scene with a mirrored ball (light probe) HDRI image, sometimes its even just a standard sRGB image. This works great for reflections but the resolution and detail from a mirrored ball image isnt great to use as an actual backdrop.
    Also... I see a lot of HDRI stock libraries seem to offer their 360 degree environments and HDRI images in the rectilinear format. This seems to give a lot more of the actual environment with less distortion and better detail.
    Does anyone know if there is a way to use rectilinear environment maps in Lightwave instead of using Image World which seems to only support the "mirrored ball" format?
    Scott
    Cape Town, South Africa
    http://www.youtube.com/user/independentvfx
    Aug 2016
    a place
    1,528
    textured environment, spherical coords Y
    Nov 2003
    jersey
    5,666
    Yep.
    Also... image world doesnt actually want to be used with mirrorball images, it should be used with angular map format. These look similar to mirrorball (they're round) but actually arent, the image is "distributed" over the disc differently such that when wrapped to an environment, you get equal resolution in all directions with minimal distortion.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    YES! Thank you so much for that... at first it wasnt working for me because I was applying the texture with planar projection (like a jackass). Then I read your message again and realised you had said "spherical".
    After changingthe projection to spherical it works perfectly
    Thanks again
    Scott
    Yep.
    Thats interesting... everytime I post a question on these forums I learn something new. Or I learn that what I thought I knew was innacurate. Is there a way to convert between these formats? And which format is the best, or most beneficial?
    Scott
    Nov 2003
    jersey
    5,666
    Ye olde HDRshop does it just fine, you may be able to find a copy (of the old discontinued and free/open V1) floating around online somewhere. As to which is better... angular map always had good stuff going for it in respect of not having any "resolution distortion" across the enviro, but frankly... unless you're making your own I'd venture that best means "most available", which these days is generally rectilinear, and Id also guess that such become most popular because of the confusion between mirrorball and angular map formats.
    RHN Nodal Tutorials
    I absolutely have to share this awesome resource. Im sure many of the seasoned HDRI veterans will already know this site, but its a new find for me and its absolutely great. Free HDRI environments and the quality looks really good from what I can tell.
    HDRI HAVEN:
    https://hdrihaven.com/hdris/category/?c=all&o=popular
    Scott
    there is no sanctuary....
    Mar 2004
    Rochester Hills, MI USA
    436
    Quote Originally Posted by scott.newman.ct View Post
    HDRI HAVEN:
    It is, I signed up as a patron, very cheap and you can sync for instant access from your hard drive.
    Bill Carey
    I7 6700K 4.0 ghz
    Win10 Pro 64bit
    32gig Ram
    Nvidia GTX 980 4 gb 417.71
    LW 2019.0 x64
    Space Navigator
