Thread: Any vector drawing tools in LW?
    Hi, all. I'm depending on a book written for LW v9 to learn how to use the LW2015, and I have run into a problem: the toot involves drawing a profile of a bowl with Spline Draw, then lathing it. Is there any way with Spline Draw or any other Draw tool to draw anything but a curve? Straight lines are thin on the ground, and after using Adobe Illustrator for many years, I can get pretty uncomfortable drawing a bowl in vertical section that has a wavy, lumpy bottom. Is there any way to draw a straight line with any of the draw tools? Or, even better, draw a line that is straight in places, curved in others? Like a vector tool?
    BC
    Jan 2005
    Colorado Springs
    1,633
    The trick to straight lines in a curve of any sort (subpatching, modeler curves, etc.) is to use multiple points (or edges on subpatched objects) to tighten corners or enforce specific coordinate values you want. I don't use Spline Draw for this type of profile work but just use Add Points to rough-in points approximately where I want them making sure to add at least three points close around each "sharp corner".
    Once it's roughed in, use CTRL-T (move points) and CTRL-H (scale) to fine-tune the curve. If I find I need more control points to have a straight line or tighten a sharp corner, you can use Polygon Mode to select the curve and Multiply=>Subdivide=>Add Points to add control points where you need them (be sure to have the action point of the tool right over the curve when clicking!).
ID:	143888 Click image for larger version.
    Note that by using the very close together triple-points at the bottom corners, the base of the goblet is perfectly straight, even though it's a "curve":
    Here's a quick video to create the goblet above using this technique. I didn't need any more control points, so I didn't use the Subdivide=>Add Points.
    GobletProfile_Annotated.mov
    mTp
    7,729
    I disrecommend using spline for profile for Lathe tool (at least not directly), as there is no control to how many segments curve will be quantized (just Curve Divisions: Coarse, Medium and Fine).
    In other words: you will get very dense mesh.
    If you would get EasySpline http://easyspline.trueart.eu
    It has tool Spline Density, which takes number of segments as parameter, to which spline will be quantized.
    After quantization (freezing) of spline to 2 point polygon chain, you would use profile for Lathe.
    EasySpline has also spline-compliant version of Lathe:
    https://www.youtube.com/watch?v=eAeIoL-fR9k
    It does not quantize/freeze spline, but multiplies spline and generates entire spline-cage.
    LightWave Plugins
