Thread: TC1 Headphone Audio Delay
    Feb 2017
    Earth
    6
    I'm in need of a solution to remove the audio delay from the audio out on my TC1. I have a podcast and want all participants to wear headsets. I tried the headphone out to my headphone amp, but the delay drives me crazy. If I go directly from the mic receivers I have to run multiple XLR's and it's all mono. Any ideas or solutions would be greatly appreciated.
    Sep 2005
    NewTek
    1,685
    If you want IFB for your guests you are going to need external audio hardware to accomplish it.
    Zane Condren
    NewTek Inc.
    new.tk/call
    Apr 2008
    Racine
    1,599
    Quote Originally Posted by TysonSugi View Post
    By delay, I assume you are referring to hearing an echo of your own voice when you talk? If that is the issue, you can certainly set up a mix-minus using the matrix audio routing to create a feed of all audio sources except your own. I don't know how many participants you have in studio there. As there are a total of 4 audio mixes available, and assuming of course that one needs to be the Master output to your audience, that leaves you 3 potential custom mixes (Aux 1, Aux 2, Aux 3). And those could then be routed to specific outputs on the rear to feed ear pieces or headphones, so I believe you could create and monitor 3 unique mix-minus outputs.
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
