Thread: Fiber FX LW 2018 - Where to start?
    Nottingham UK
    2,756
    Hi All,
    Iíve got some models with ZBrush Fibermesh hair Iíd like to bring into Lightwave and apply Fiber FX to, initially just for rendering but later dynamics. Iím also really looking forward to testing the new renderer on character head models.
    Iíve checked the manual but unless Iíve missed something, I canít find a clearly defined workflow. Iíd be really grateful for tutorials or up to date advice, using ZBrush splines as hair guides. FiberFX has gone through so many changes itís a little confusing.
    PS My Artstation link has work done in Maya XGen and Arnold for work but I really want to spend more time in my original app Lightwave.
    Registered User Oldcode's Avatar
    Jan 2004
    Boston
    371
    Export the hair from ZBrush as an OBJ and then bring it Modeler. Got to Edge Mode and copy its edges by hitting the "w" for the Statistics window and select only the 1 point polygons and copy it. Don't paste yet. Go to Polygon mode and delete all polygons, then paste the edges back. Save as a LWO. See if this works. I've used this to get Blender hair into Lightwave, but only tried it once with ZBrush hair.
    Good Luck,
    Nottingham UK
    2,756
    Quote Originally Posted by Oldcode View Post
    Good Luck,
    Thanks Oldcode, sounds doable I’ll have a go with that.
    In ZB there is the option to export as LW curves... would this work?
    How best to parent the two point polys to the scalp?
    Cheers
    14,367
    Quote Originally Posted by bobakabob View Post
    Thanks Oldcode, sounds doable Iíll have a go with that.
    Cheers
    I havenīt gone through the zbrush to lightwave process, I think Lino and maybe someone else has it covered when it concerns fibermesh to lightwave, If that still works in 2018
    O yeah...
    If you are using bullet, you really do not need to parent it..well perhaps you do when I think about it, if you have strands that is inside of another mesh that also is a bullet dynamics object, like static...the strands will be hooked inside that mesh, then again...you may not want to make a character a certain kind of bullet type, so making a dummy object cage of lower res and parent that cage to the main character I think should work, and then make sure the strands are inside of that cage.
    You can also parent to a bone.
    Nottingham UK
    2,756
    O yeah...
    Perfect, thanks for the link and suggestions Prometheus!
