Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
Thread: Fiber FX Question...
  1. #31
    I've tried different values on it, inverting the gradient, changing the alpha...as well as having clump set to 100 and 0...be nice if you could see weight values in modeler on 2pt polys.
    Rob Depew
    Modeler/Animator/Editor
    Visit my Web Portfolio
    Lightwave3D 2018, Chronosculpt, RealFlow and more..
    Threadripper 16 core, 48gb, GTX-1070
    Asus ROG 752vt i7 2.6 x 4, 48gb, GTX-970
  2. #32
    pass:sword OFF's Avatar
    Russia
    921
    Try 'Fiber V' as Input Parameter instead Weight map.
  3. #33
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,334
    I'll zip up my test scene and upload it later today (I have appointments this morning). I used fiber-v for my input on the gradient, with the beginning (paramter = 0.0) set to 0% (No Clumping), and the end (parameter = 1.0) set to 100% (Clumping 100%).
  4. #34
    14,111
    Yep..that is probably better to ensure that the clumping gradient following the strands properly.
  5. #35
    FiberV gives me the same result....
    I can invert the values, etc and never get the ends to taper in, always the other way.
    Rob Depew
  6. #36
    Feb 2009
    Prescott, IA
    1,334
    Make sure that your original guide splines have their start point where you want it.
    I got similar results to yours when my guide was 'backwards', ie, the start point for the curve was actually the end point...
    Here is my base object, a simple helix. I'm using the spline, not something fed through strandmaker. Unless you need 2pt polychains, you don't need to both with it.
    No clumping, no kinking of fibers. 1 Fiber, Guide radius of 20mm, 200 clump fibers, 12mm radius. The start point is on the lower left.
    Same spline, with clumping applied, using Fiber-V. Comes to a nice, sharp point. Again, the start point is at the lower left.
    Same spline, with the start point at the opposite end, up at the center, top. Look familiar?
    I would go back into modeler, and check your original guide curves you used to make your guide chains from, and make sure the start points are where you need them to be.
  7. #37
    Im using poly chains, not splines. Maybe I should convert them to splines?
    Rob Depew
  8. #38
    I changed one to splines rather than poly chains and now fiberv works as expected. Thanks.
    Ok I havent used them in layout so much, and wondering if the splines can be used with dynamics? or at least rigged?
    Rob Depew
  9. #39
    Feb 2009
    Prescott, IA
    1,334
    I believe they have to be 2 pt. polychains for rigging and dynamics. Feed your splines through Strand maker, and you should be good. You'll have to add any weight and uv maps you need to the chains (Usually, it's fairly simple stuff. Ken Nign's Weight Outwards lscript helps a lot.)
  10. #40
    Hmm...but if i use polychains, then I lose the ability to control the size...lol
    Rob Depew
