Thread: Layout message error
    Dec 2017
    blue
    31
    Hello,
    I do tests with particles, hypervoxels and from time to time I have this message 'pfx no calculable dynamic enable'. And since I still have not got everything right ..
    Thank's
    14,496
    Quote Originally Posted by Obi View Post
    Hello,
    Thank's
    Make sure your pfx emitter is active, in the fx tab the ..where it says "On", you need to have that with a checkmark beneath it..to ensure the emitter is active, otherwise it can not recognize any pfx as enabled.
    You may have accidently unchecked that..or forgot to activate while testing things.
    This thread and itīs questios is more fitting to post under Lightwave 3D support/General Support.
    Dec 2017
    blue
    31
    hello prometheus
    the option is enabled. I have recomposed and I break down my action;
    1) I create a 'null'
    2) hypervoxel activate in volume for example
    3) property of the 'cloth fx' and 'fx collision' object
    4) calculate .. and this error message
    I create a new post in the right section?
    Dec 2017
    blue
    31
    in writing I understood my mistake ..
    I got lost because I try to have a number of particles to create and that remains in an area defined as a bubbling
    14,496
    hello prometheus
    Let the forum moderators take care of that(moving the post) if they see that as more fitting, no need to create new posts.
