Results 1 to 14 of 14
Thread: Nested Macros
    Jan 2018
    Winter Park
    249
    Nested Macros
    I believe I have read on here before where people have macros that call other macros.
    I setup a new macro and called other macros by using the control surface. I notice that it brought in 3 commands:
    surface_macro_changed - true
    surface_macro - the button assigned
    surface_macro_changed - false
    doing a text search through the Automation and Integration guide didn't yield any hits to better explain that the first and last bit are doing and if this is the best way to call a macro from a macro.
    Thanks guys!
    19,296
    There are lots of undocumented shortcuts, but really the intention of leaving them undocumented is that they are pretty much irrelevant aside from special cases that they were implemented for. To run a macro by name, I would usually use he shortcut play_macro_byname.
    They best way to do this is to use the 'play_macro_byname' shortcut.
    Create a new macro, for the shortcut type in 'play_macro_byname' then in the value column enter the exact name of the macro you want to run.
    Key Accounts Sales Engineer
    Jan 2018
    Winter Park
    249
    Thank you both for pointing me in the right direction. I would love to see all the extra little features to see what I could come up with ;-) I will put autocomplete into the wish list as I build these things out. Very powerful stuff.
    Jun 2012
    Europe
    191
    Can't wait the day we'll be able to activate/desactivate a macros folder through another macro.... would be very useful.
    19,296
    It's coming: macro_is_enabled_byname (but I think you knew that)
    Jun 2012
    Europe
    191
    No, I did not, good news ! Is it already working in recent versions ?
    19,296
    Quote Originally Posted by doctorsunshine View Post
    Oh, sorry! The request originated in Switzerland, so I jumped to a conclusion ... silly me.
    I tested it in today's build of 7-0, and it works, but I haven't tried either 6-0 or the current release version. Here's the syntax, if you want to give a go:
    macro_is_enabled_byname | macro_name="name of macro" | is_enabled="true"
    Jun 2012
    Europe
    191
    Ha you might be right, I made a feature request for that some time ago. But I did not get feedback it was coming...
    19,296
    I'd be interested in one or two practical examples of how you envision taking advantage of this ability, if you feel like bothering.
    Jan 2018
    Winter Park
    249
    If you mean the calling macros from macros,
    I have a number of macros that fire around doing some replay stuff and at the moment they are based around time. For volleyball we do a 6 second replay after points so I want things to happen prior and then wait 6 seconds and fire off again. When I goto soccer that changes out to 10 seconds. I can either duplicate my macros and have one for soccer and one for volleyball and enable the right set. My thought was to have the delay to return graphics etc inside a single macro and that way I could update 1 macro (the wait) and it would impact all 4 of my replay macros without having to edit each one.
    With that being said I did start playing with Automation last night and for show on reply I was able to just put the return of graphics in its own macro that I call when DDR2 leaves program which works really nicely. The only part Im trying to figure out now is that I have a replay that is setup on an ME with a PiP so I can still show live action. The issue I found is that the MEs do not appear to have an automation tab for some reason. As such I cannot set that one to bring the graphics back up when ME1 leaves program.
    19,296
    Thanks, but actually I was referring to the enabled/disabled toggle ... sorry I didn't make that more obvious.
    Jan 2018
    Winter Park
    249
    I figured, I just wanted to talk :-p
    19,296
    It''s always quiet in here on Fridays ...
