Results 1 to 12 of 12
Thread: TriCaster -> iMovie problems
    Oct 2018
    San Antonio, TX
    4
    I'm unable to view/edit my TriCaster output video in iMovie. The video imports into iMovie but there is no video and only audio. I have installed the NewTek codecs. I am able to view/edit the video with a different application on the same machine (Lightworks), though. Should I be able to use iMovie?
    Here's my setup:
    TriCaster Mini AE2 default video format (Lightworks reports the format as: XDCAM HD422 1080i60 CBR50)
    MacOS Finder says the video has Codecs: Linear PCM, Timecode, MPEG-2 Video
    MacOS: 10.14 (same behavior on 10.13)
    iMovie: 10.1.9
    Thanks,
    Stephen
    it took me a lot of years to find that switch!
    Look at the settings connected to the Program view. There is a menu setting to change what kind of file is saved. You can do avi which will easily import into imovie.
    Robert Wilson, MA Deaf Ed.
    Indiana Deaf School
    1,437
    Hi Stephen,
    You might need the XDCAM codecs installed for QuickTime since that is what Newtek is using as of late.
    Robert - AE and TC1 TriCasters no longer offer the AVI or MPEG record options, records as QuickTime .mov only (well, plus .mp4).
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Yikes.
    Our machine was thought to have the latest upgrade. Perhaps not.
    Thanks for the info.
    Robert
    Indiana Deaf School
    1,437
    Quote Originally Posted by [email protected] View Post
    Yikes.
    Robert
    The "auto update" business on TriCaster is unreliable. In the LIVE interface, press ALT-B and it will show currently installed software version at top of screen. I always do manual download and installs myself.
    Jeff
    Jeff Pulera
    I just installed iMovie v10.1.9 on OSX 10.13.6. I didn't test every recording video format, but I appeared to be very similar in compatibility as I find with Final Cut Pro X (which isn't unsurprising). It is possible that FCPX is installing some additional codecs on the system that could be helping, so I would install the FCPX trial on the system to get those codecs installed. Even after the FCPX trial ends, the codecs will remain on the system.
    https://www.apple.com/final-cut-pro/trial/
    Here is a list of media compatibility with major applications, iMovie should be similar to FCPX in this list.
    NewTek Recording Formats.pdf
    Oct 2018
    San Antonio, TX
    4
    Thanks for the replies. I installed FCPX but it is behaving just like iMovie and Quicktime (no video (green screen only) with audio working).
    I am able to view/edit the video with Lightworks on this Mac. I assume it uses it's own codecs instead of the system codecs??
    I've installed the NewTek SpeedHQ codecs several times on this machine. Is there anyway I can verify if they have installed correctly?
    Any other ideas?
    What version is the TriCaster software? It is at least at the version numbers in the PDF?
    Oct 2018
    San Antonio, TX
    4
    My TriCaster Mini is at: Build Number 5-1-180706C. I think that is greater than the PDF, if I'm reading that right.
    Oh, but now I'm understanding the compatibility chart better in the PDF. I am recording in 1080i, so it looks like I shouldn't expect compatibility with FCPX, right? (or Quicktime/iMovie)
    So, I guess I need to select a different recording format if I want compatibility with FCPX/iMovie? Is that selection determined when creating a new Session?
    Correct. From what I have gathered, Apple's decompressor doesn't support MPEG2 Field Picture Mode used by interlace recording. Anything that is progressive will work correctly.
    Oct 2015
    Israel
    77
    Had the same with issue with a customer that tried to edit in IMovie
    Eventually - I converted all the files to MP4 with Any Video Converter
    https://www.any-video-converter.com
    You can also export from the TriCaster in ProRes format, then the files will come into FCPX or iMovie in any video format that you want to use.
