Results 1 to 8 of 8
Thread: Youtube streaming error
    Oct 2015
    Israel
    77
    Managed to do streaming with the SE.
    Just purchased the AE - trying to do streaming: getting the following error (attached screenshot).
    Error: Streaming: Encoding Setting Error: May be bitrate, width or height.
    Any idea why?
    There is a knowledge base article on how to fix this.
    https://support.newtek.com/hc/en-us/...e-Width-Height
    Oct 2015
    Israel
    77
    Thank you Kane! will try that.
    Oct 2015
    Israel
    77
    Hi Kane,
    I installed the new driver - its working great...
    The only thing is that the window popup coming after signup taking 30++ seconds - don't understand why.
    Is it because of the API ?
    Popup window? Can you post a picture so I can see exactly what you are seeing?
    Oct 2015
    Israel
    77
    What I meant that its taking 45-50 seconds to pull the data from Facebook for example. (didn't shoot the earlier stage when I sign in - also took 1 minutes)
    Is it what its suppose to take ?
    Here is a short video I took:
    https://youtu.be/JUonBtHUJFA
    Not sure, I just tried on my system running 5-1-180911 software and it only is taking a few seconds for that window to connect and display information.
    Also, Facebook only supports a maximum of 720p resolution, anything higher is down scaled to 720p.
    Oct 2015
    Israel
    77
    Thank you Kane,
    Will follow on that. see if it happens again.
    Thought its connect with the Newtek share app.
    Or maybe because on that account I have many sub pages it takes time. (will check on the other accounts as well).
    Thanks again,
