Results 1 to 10 of 10
Thread: Squeeze a ball through a hole.
    I'm looking for a little help on how to set up squeezing a sphere through a hole in another object. I know I've seen demos of things squeezing/being deformed as they pass through another object but I can't remember how it is done. Looking for advise on what the easiest way is to set something up like this in 2018.
    Thanks in advance.
    Wayne
    Medical Animator mummyman's Avatar
    Aug 2009
    Connecticut
    981
    I guess it depends on how much time you need to spend on it. I've used cloth FX, bullet, and deformations in 2015. I haven't had to use 2018, but I'm assuming all the methods still apply. Deforming using a null and effector for making a sphere move through a cylinder shape to swell it.
    Jan 2005
    Colorado Springs
    1,603
    It might not meet your needs, but you might be able to use the Deformation modifier Taper. LW2018 sample scene attached.
ID:	143065 Click image for larger version.
ID:	143066 Click image for larger version.
ID:	143068 Click image for larger version.
ID:	143069 Click image for larger version.
    SqueezeBallThroughHole.mov
    The setup is to create two Nulls called TaperBase and TaperHandle. You then use the Ball's Object Properties=>Add Modifier to add the Deform:Taper deformation handler. Double-click on it to get the options panel, specify the TaperBase and TaperHandle nulls, and in this case I chose the Ease Out preset curve shape and the Z axis:
    The Taper deformer is controlled with the Scale of the control nulls. TaperBase null is placed down the -Z axis and remains scaled to (1,1,1) throughout the animation. The TaperHandle null is scaled down to squeeze the Ball through the hole in the plate. Both TaperBase and TaperHandle are moved up and down the Z axis to control the animation as the Ball moves down the Z axis.
    Here's a Top view Preview showing the movement of the TaperBase (green) null and the TaperHandle (yellow) nulls:
    SqueezeBallThroughHole_TopView_TaperDeformerNullMovement.mov
    The scale "wobble" after the Ball comes through the hole was keyframed on the Ball's scale channels.
    Although it's fairly quick to setup and control, the Deform:Taper modifier may not give you as much control as you need, but may be worty a try.
    mTp
    Attached Files Attached Files
    Last edited by MonroePoteet; 10-10-2018 at 07:42 PM. Reason: Sample scene is LW2018; typo
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,095
    3rd Powers Lattice Deformer can work for this: http://www.3rdpowers.com/index_store.html
    May 2003
    Ohio
    606
    LW7.5D, LW2015.3, LW2018.0.x running portably on a USB drive on an Amiga 2500 running Wine.
    Registered User ianr's Avatar
    Oct 2006
    Chiltern Riviera
    1,289
    Quote Originally Posted by lertola2 View Post
    Ain't that soo smooth, a lovely example.
    I hope he got some more plugs up his sleeve?
    Carbon fibre dongleŽ 50one's Avatar
    Jan 2011
    Glasgow
    2,365
    I can do this in Cinema, Max, Modo, Blender and possibly export .mdd too. Shame for such a simple thing you either have to wrestle displacement nodes or buy a separate plugin.
    May 2003
    Ohio
    606
    Quote Originally Posted by 50one View Post
    I cannot recall the method but I vaguely recall this was one of the exercises taught when I was learning LW on Amiga, without any third party add-ons.
    14,259
    You don´t
    You can do it with Lightwave bullet deforming body. for initial test I did within some minutes, you should use shape lock and a shape retention value, turn off gravity if you want to manually just move the ball through the hole., (unless using a kinematic item to hold it during gravity and then push it.
    Use a lower frame rate initially to get decent realtime respons, and raise it later when playing the sim for more accurate behavior, set a high linear stiffness..if not 100%, volume scaling and conservation maybe 100%
    May 2003
    Ohio
    606
