Thread: Got a problem
    Mar 2011
    Fort Wayne Indiana
    95
    Got a problem
    Over the last couple weeks when I render an Daz Studio character in Lightwave. The end render looks correct. When I bring it into Photoshop the hair comes out as transparent. Would anyone have an idea how to render this with the hair not transparent? I have changed the way I render the photo and get the same each time.Click image for larger version.
    Pasadena, CA
    1,019
    Most likely it has a different transfer mode or layer order that's not in agreement. I've encountered this before; wa an easy fix just took a little fidling to find the culprit.
    Aslo, if you aren't, using FBX to export out of both Daz & Poser (stick with the 2014 version though) simplifies the process a great deal.
    Mar 2011
    Fort Wayne Indiana
    95
    I worked on it again today and I saved it out a tif with 24 bit and it came out the way it looked. When I saved it out as a 32 bit tif is when I have the problem. So is a 32 bit, a 24 bit picture with an 8 bit alpha. How can I save it as 32 bit then.
    Pasadena, CA
    1,019
    Quote Originally Posted by grafxstudio View Post
    Take a look at the tif. It might be a 32-bit file but does it actually have alpha info? If it's solid white or black it's doing no good.
    You might consider png format. Lossless, tiny, and can have a alpha or rather have transparency.
