Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: Controlling speed of travel along a spline/path
  1. #31
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,048
    Another possibility is that the null controlled MANY other items.
    I can certainly see how this would be convenient if one were, for example, animating a bird's eye view of a car race with a basically circular track, but not an actual circle. Each car would get a "throttle", and blah blah blah. Of course, by the time you got this system working, you could have animated it w/keyframes three times over.
    Still, it'd be nice to know if the overall system is flexible enough to accommodate such constructions.
    It is possible and you could use the techinque I showed in my recording. You can link as many objects you want to that animation channel you can even do the animation on a Null object and link all others to that. Whatever you do, if you want to animate the throttle you need to create keyframes and you’re back to square one or you could use a procedural texture to drive the animation without keyframes.
  2. #32
    Axes grinder- Dongle #99
    Seattle
    14,726
    Quote Originally Posted by Ztreem View Post
    Ztreem, thanks: I'm housesitting and away from my LW station until Wednesday. I look forward to seeing how this was solved.
    Praise to Buddha! #resist
  3. #33
    Jun 2003
    Sweden
    4,048
    I don't know why I do this or why I care but here is a similar setup with a different approach. I just like solving others problems instead of my own.
  4. #34
    Seattle
    14,726
    LOL, we identify and appreciate. Other people's problems are more interesting, our own are just frustrating.
    On the subject of justifying or rationalizing this general approach: I'm #aflw but, keyframing item positions could be quite finicky and a tedious drag, while speed control along an established track should be a doddle, even though you'd still be keyframing the controller.
    Again, #aflw, but has anybody turned on LSCommander to see how much of the workflow gets captured as commands? Ideally, this would be ALL OF IT, and one could set it up with a push of a button (linked to an LSCommander derived lscript).
