View Poll Results: Do you use the Hub?
Voters
120. You may not vote on this poll
  • OSX - Always
    14 11.67%
  • OSX - Sometimes
    3 2.50%
  • OSX - Never
    1 0.83%
  • Win - Always
    69 57.50%
  • Win - Sometimes
    11 9.17%
  • Win - Never
    22 18.33%
Page 1 of 4 123 ... LastLast
Results 1 to 15 of 51
Thread: Do you use the Hub?
    Pessac
    5,018
    Do you use the Hub?
    The question is simple, do you use the Hub with LightWave?
    B
    PS. I realise now that I should have approached the poll from the other direction "Do you disable the Hub?", with exactly the same answers, but it's too late now.
    LightWave 3D Trial Edition
    AMD Threadripper 1950X, Windows 10 Pro 64-bit, 32GB RAM, nVidia GeForce GTX 1050Ti (388.13, 4GB and 768 CUDA cores)
    Pessac
    5,018
    Obviously, for people who actually use both platforms, you only have one vote in a poll. Vote for the option that best represents your work overall, but feel free to post a reply to the thread as well.
    B
    i do,
    i'll say it again though, Modeler / Layout should use the same C/C++ code,
    then none of this HUB/split-app stuff would've been a problem.
    and it would cut the "maintain code" issue in roughly half.
    Enhanced Low
    Jun 2003
    Sesam Street
    603
    I don't understand the question. What do you call "use" the Hub. It launches alone and works alone. What would one have to specifically "do" with it ?
    over the years, some have reported HUB problems, so there's a certain percentage of users turning it off.
    Quote Originally Posted by lasco View Post
    X:\LIGHTWAVE20153\bin\Modeler.exe -0
    X:\LIGHTWAVE20153\bin\Layout.exe -0
    London
    2,302
    On OS X, yes, but getting really tired of it’s (and Modeler) constant crashing in the background while using Layout. Been like this throughout LW2018 and can’t report because I don’t know how to reproduce it!
    Grafiks iz us dsol's Avatar
    Sep 2003
    London, UK
    1,854
    I do, it sometimes saves my bacon if Layout or modeller crash. I'd prefer to have a unified app though!
    Dan Sollis : Independent CGI Designer & compositor
    Digital Distortion : Post Production for Film and Television
    http://www.digitaldistortion.net
    http://www.londonlightwave.org.uk/
    Living over there... MAUROCOR's Avatar
    Jun 2004
    Sao Paulo Brazil
    2,434
    Quote Originally Posted by dsol View Post
    Ground control to Major Tom
    Jan 2005
    Colorado Springs
    1,691
    I don't explicitly disable the Hub (which might have been a better survey question - sorry, BeeVee! ), so I "use" it. The models / scenes I work on are usually very simple, and since that's one of the primary functions of the Hub, I may have just lucked out. It does crash occasionally under LW2018.0.5, as well as Modeler crashing. They restart just fine so I haven't been disabling it. I still haven't detected a specific workflow / action that causes the crashes, though.
    mTp
    I started using Lightwave with version 6. I think that was the first version to have the hub so for me it has always been a part of Lightwave I have accepted as the norm and used.
    Pessac
    5,018
    @MonroePoteet, you're right! Still the same options, but the question reversed - "Do you disable the Hub?". Oh well, next time.
    B
    May 2003
    Ohio
    692
    As users may be unaware of its presence and what it does, it may be ideal to ask "do you intentionally disable hub.exe?"
    EDIT: oops. I took way too long to type something already said.
    I have found flakeyness in 2018 with what I presume is Hub related. You can make changes to surfaces in Layout and then decide you need to send the object to Modeler to change some geometry and then all of a sudden your surface changes are gone. I don't recall that happening in 2015,11,10 etc.. And yes, maybe saving the object beforehand would be prudent, but still I don't think this is right.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Registered User jbrookes's Avatar
    Jul 2008
    Unknown
    197
    I've never really had a need to use the Hub. I see it more as a convenience and don't really use it.
    One of the first things I do after an install is (Windows) Right-click the desktop icon, select Properties, and insert -0 after the file path.
    Favorite Waves: LW3.5, 5.6c, 7.5, 8.5, 9.6, 2015.
