Thread: Dissolve Dielectric material after two rays?
    Jun 2010
    Kranj
    98
    Hi
    Is it possible to setup glass material to just 'disappear' after first two rays?
    The reason is that I am getting really low render times if I reduce ray recursion limit from 6 to 3, but if I render corner glass window I need more rays to pass through both glass panels otherwise I get black area.
    I can remove glass panel that is behind the first panel, but that is just more work in modeler etc...
    I saw a dissolve input in ray type switch node, but I don't get wanted results.
    Is it possible?
    Best regards
    Matej
    7,630
    Try using Material Tools > Switch.
    In Input node get Bounces, plug it to Math > Scalar > Logic node (A input), set up less or equal to 3 (or whatever) (B input), and use it as source of True in Switch node.
    2nd material set up Standard material entire black with everything cleared and plug to Switch False.
    Adjust Logic B input to see whether there is visible any change.
    Just a thought.
    LightWave Plugins
    Global Materials for LightWave 2018!
    Jun 2010
    Kranj
    98
    Found it
    6,071
    (removed due to error)
    LW2015.3UB/2018.0.5 on MacPro(12C/24T/10.13.6),32GB RAM, NV 1080ti
    7,630
    Quote Originally Posted by medzo View Post
    Found it
    I like it.
    The more optimal than my approach (although using my Logic node)..
    In older LW you would not be able to do it this way, as there is no Clip input.
    LightWave Plugins
