Results 1 to 10 of 10
Thread: Model not updating in layout
    Apr 2011
    Port Orchard, WA
    17
    All of a sudden I think I've lost my mind. It seems that when I have had modeler and layout open at the same time in the past, I could modify the model and switch to layout and the model would automatically update with the changes. This appears to be no longer working. Hub is running and seems to be working.
    Any clues? I am having a major brain-fart on this one. Stupidly simple answer, I'm sure. Lightwave 10.0.
    ack ack Markc's Avatar
    1,226
    Have you tried the update layout button in modeller before going back to Layout.
    I know this was an issue with earlier versions of LW2018 (now fixed). My workaround at the time was to re-save the model and it would update in Layout.
    Mac Pro (2010) OSX 10.13 RX580 Pulse LW2018
    Axes grinder- Dongle #99
    Seattle
    14,715
    FWIW, I've always found that SAVING in LWM updates Layout reliably.
    Praise to Buddha! #resist
    Apr 2011
    Port Orchard, WA
    17
    Moot Point Now
    Yea did all the stuff from both replies and no cigar. Just deleted and added the model back in. Had a bit of a hassle with scaling and position but all is well now. Strange, thanks for the feedback.
    Seattle
    14,715
    Quote Originally Posted by sdilling View Post
    If you can get it to repeat, submit a bug report. It's not so bad if it's not rigged or animated, but it would suck if it was.
    1,226
    I don't think a bug for LW10 will be fixed now.......
    Seattle
    14,715
    But it might PERSIST up to this version.
    1,226
    Good point.....
    Ohio
    533
    While you may not have updated LW, Windows may have been updated over the years. Evolving Windows tech like the firewall and UAC (aka "needing to run older apps in admin mode") may cause older software to be quirky. Make sure the apps (layout/hub/modeler) can run without these newer restrictions.
    LW7.5D, LW2015.3, LW2018.0.x running portably on a USB drive on an Amiga 2500 running Wine.
    6,071
    IIRC, LW10 was the initial incarnation (hmm, or maybe was 9.5/9.6, anyway...) of then-new "hubless" cross-app updating mechanism. It did require certain flags to be provided in cmd line args (in icon, see docs) to tell LW to use it. Otherwise, if the hub was running LW used the hub, and if hub wasn't running and cmd line changes weren't present LW behaved as if no hub (== no auto-updating between apps).
    Hub was notoriously problematic thus the introduction of then-new approach that didn't rely on hub. However, if hub is running, LW uses hub preferentially over other system, so (IIRC, again) you have to both have cmd line mods and NOT be running the hub (another LW cmd line change in Windows) in order to use the then-new hubless mechanism. I'm pretty sure that's what you're remembering (your description fits how it worked).
    Maybe you had the cmd line changes once upon a time, but the shortcuts associated with those changes got deleted?
    LW2015.3UB/2018.0.5 on MacPro(12C/24T/10.13.6),32GB RAM, NV 1080ti
