Results 1 to 8 of 8
Thread: Follow path timing? Rove across time?
    digital witchdoctor objuan's Avatar
    Nov 2003
    Denver, CO
    522
    Is there a way set up a curvaceous motion path with 5-8 keyframes, and then animate the speed of your object along that path separately?
    In After Effects you can create your path, and then tell the middle keyframes to ROVE ACROSS TIME which makes the object step even intervals along the path. Then you can, say, tell the end keyframe to ease in, so your object will start moving fast along your curvy path and then slow to a gentle stop at the end. This is more or less what I want to do, but with semi more complex timing.
    ??? How do I do this in LW ???
    I messed with curve to path out of Modeler some, but as near as I can tell, that just gives you even more keyframes to be unable to massage the timing of.
    I seem to recall seeing a tut a long time ago where dude had a space ship that transformed, and several different parts folded out and clicked into place, and then he rigged the entire animation to a slider or null, so he could control it with just that. I suppose something like that would work, but I forget even what to type in to try to look it up?
    As always, any help would be appreciated.
    Ocean Byrne
    humble pixel farmer
    www.moceandesigns.com
    DP motion info
    London
    2,323
    Would love to see this feature. Here’s something I played with that does what you need but may need some familiarity of Motion Mixer:
    https://youtu.be/ytvRg_DsyUQ
    May 2010
    England
    33
    That video you're talking about with the rigged spaceship sounds like William Vaughan's the "Introduction to Cyclist" video. In the 24 hours of Lightwave training sticky thread.
    http://forums.newtek.com/showthread....ng-(24-Hours-)
    May 2010
    England
    33
    Heh, ask me to remember a name, phone number or a thing to do and I'll probably forget. Ask me which one of 250+ videos that i watched 10 years ago had that spaceship animation tip in it...
    That William, He Tut's good.!!
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,128
    Use curves with curve constrain or splines with spline control to easily control ease in and out of the motion along the curve/spline.
    Nov 2003
    Denver, CO
    522
    Thanks guys.
    Ocean Byrne
    humble pixel farmer
    Nov 2003
    Denver, CO
    522
    Ha when you do a google search on a question, and what comes up is you asking the same question years ago on this forum. Thanks again guys!
    Ocean Byrne
    humble pixel farmer
