Thread: what causes these jagged edges when rendering
    Newbie Member
    Nov 2006
    Birmingham
Name:	what causes this.jpg
ID:	141932 This is a render of lightwave render scenes 5 lws
    Jan 2004
    Broken Arrow, Oklahoma
    929
    Have you tried something larger in resolution? Seems like just a pixel issue on an angle....which you'll need more pixels to smooth out. I had a hard time at first seeing them...until I zoomed in past default resolution.
    San Antonio, Texas, USA
    13,026
    Quote Originally Posted by spiderman View Post
    Too low anti-aliasing settings most likely
    UI Designer @ NewTek
    For this size render, I think it looks just fine.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Nothing ado about much Exception's Avatar
    Netherlands
    5,555
    Funny, I once made that scene 10 years ago
    Yes, looks like you just need to turn on Anti Aliasing. Higher resolution helps to see it better.
    Mar 2012
    Socal
    295
    If the pixelation is on the threshold of bright areas, it's a problem inharent in CG in general. Think of a case where you have several pixels next to each other. There may be 8 pixels that have a relatively low value like 0.5ish, then there's one pixel in that area that has a super high value, like 1000,000ish. When you average those pixels (which is what antialiasing does), even though there are more pixels with a low value, the one with the super large value is dominant, causing the average pixel value to look jagged.
    The answer is either limiting your dynamic range, or using a filter to better distribute the error over a larger number of pixels, ei, using a bloom filter. That's generally what happens in the real world when you look through a lens.
