Results 1 to 8 of 8
Thread: LF OBJ to PFX plug-in
    Pasadena, CA
    1,019
    Watching an older Bullet video and this plug-in is mentioned. Unfortunately, when looking at http://www.lightwave3d.com/assets/pl...entry/obj_pfx/
    http://www.vuescripts.com/_A/index.php?aid=85
    The link is dead.
    Is there an equivalent for 2018 perhaps or might this still be available at some obscure repository?
    Super Member Kevbarnes's Avatar
    Nov 2006
    Gloucestershire UK
    487
    Is this what your looking for
    LF_Obj_Pfx.zip
    Also Scene file on BB8 droid uploaded to original thread
    "one rig to rule them all"
    PC Spec: Intel i7 X980 3.33GHz | 24Gb | ATI FirePro V5800 | W7
    https://vimeo.com/kevbarnes/showreel
    https://littlstar.com/kevbarnes
    https://www.talenthouse.com/kevbarnes
    Quote Originally Posted by Kevbarnes View Post
    http://forums.newtek.com/showthread....t=#post1545634
    thanks Kev  
    and Steven Cleland (author)
    Pasadena, CA
    1,019
    LF_Obj_Pfx.zip
    Ah. Thanks. I'll take a look at both a bit later.
    Jun 2007
    Napoli, Italy
    9
    Thanks me too. Please, have you got "LF_ObjTo..." too? If yes, can you share it? Thanks in advance.
    ain't got it, but try this one if you are on PC
    https://www.lightwave3d.com/assets/p...to-poly-chain/
    says 32bit, but is 64bit also
    hah! can't believe it, found it in an old archive
    Thank You to Steven Cleland
    Attached Files Attached Files
    14,256
    A note..
    The LfObj to pfx, will create a pfx particle file from any objects vertices, so if you were to move a cube around and rotate banking for instance, you would get 8 particle paths in to the pfx file, then Use Lf_Pfxto which will create 2 point polychain based on that pfx file, with those two in conjunction and using ls_pfxto in modeler to load the pfx created file, you will get 8 segments of paths as a twisted polychain based on how that cube was spinning.
